Heating & Cooling Logo
Jennifer Meikamp Posted on Jul 29, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our brand new Dometic ac unit or blower does not turn on. I flipped the breaker even though it wasn't tripped. The wires inside the inside the vent in the ceiling are all plugged in. What now?
Bart Walker
Level 2:
Novelist:
  • Expert 206 Answers
  • Posted on Aug 10, 2019
Bart Walker
Expert
Level 2:
Novelist:
Answers
206
Questions
0
Helped
71510
Points
453
It sounds like your Dometic unit is not getting power despite the breaker being on. Unless the Dometic unit has an internal fuse to check, I would get out a volt/ohm meter and check to see:
1. Is there power coming out of the breaker that goes to the ac unit?
2. Is there power at the terminals of the ac unit? (You can sometimes remove a ceiling cover to access the contacts on the on off switch.
Lastly is your RV hooked up to full power with two 110 volts on both legs beside the neutral and ground wire? If you are only feeding your RV with a standard 110 volt extension cord and using an adapter, that can mean half the circuits in your RV are energized while the other half 110 volt leg is not. You must energize the second leg by using a full 30 amp or 50 amp dual power cord.
RV's are funny. They require two 110 volt legs with a neutral and a ground. The two 110 volt legs are both of the same phase. There is no 220 volts between the two hot legs as they are in phase. A volt meter between the when hot would read zero volts, while each hot leg to neutral would read 110 volts.
Hope this helps.
5 Related Answers
ferny buentello
  • 33 Answers
  • Posted on Jul 19, 2008
SOURCE: carrier central airconditioning heat unit - breaker trips when cooling turned on
well mineswas a blowen compressor
A
Anonymous
  • Posted on Oct 31, 2008
SOURCE: Tripping BreakerS
I have the same problem with a new lg unit...it will trip the breaker after a few minutes of being on.
Anonymous
  • 3 Answers
  • Posted on May 10, 2009
SOURCE: Having problems with siemens arc fault breakers tripping
check to see if ground is connected or netural is loose
Anonymous
  • 127 Answers
  • Posted on Jul 05, 2009
SOURCE: I have a Dometic Duo-therm 1500 AC Model 59516.633C1 on my 5th wh
The clicking sound is usually the relays in the control unit making or releasing. When they click does anything turn on? Check the control unit that is located inside the lower unit of the air conditioner. Remove the cover and listen for the clicking sound. If it sounds as if the relays are clicking, try removing power from the thermostat and see if that stops it. There are three relays on the board, one is the compressor, one is the fan relay and the other is for heat. See if you can pinpoint which one is clicking and go from there. It is either that you have a bad thermostat or a bad relay board.
atocrxr
Paul
  • 144 Answers
  • Posted on Apr 11, 2010
SOURCE: ac unit breaker trips off
First thing to do turn off the breaker in the electrical panel, then open up the AC outdoor unit, including the disconnect box, that should be mounted on the wall near the outdoor unit. Go thru and tighten all of the screws and wire nuts, look for burnt wires, while you are at it.
Turn on the breaker and try again, if it still trips, then we look deeper;
pull the control panel off the outdoor unit and look for the contactor, this is where the power coming into the outdoor unit hooks up to. There will be a set of contacts in the control, check it out and see if the points are badly burnt,
If all off the wire checking still has not helped, it will more than likely be a bad condensor fan motor or a compressor, the compressor is the big black thing in the bottom of the outdoor unit, making sure that all power is turned off, pull the plastic cover off of the side of the compressor, there will be 3 wires, make sure none of them are burnt and touching the metal, if they are, repair the wire and test.
Try this and if you need to know how to troubleshoot to see if it is the fan motor or the compressor, just contact me back.
If this has been helpful, please rate me.
Contact me if I can help you any more.
Sincerely,
Paul
I have a dometic rooftop... runs for hours then trips breaker... sometimes a/c sometimes main breaker. Can something in the thermostat cause this? seems it has trouble after turning off then kicking back...
Your first thing to do is disconnect power and ck all of your wire connections in the elect box. pay close attention to the neutral wires. Also ck the wiring in the ac its self. Breakers trip due to heat build up. if the wires going to the unit are hot its usually due to a bad connection to small a wire or the breaker its self can be getting weak look for charded and melted wires replace all that look suspiciouse. I do not believe it is the AC since it runs for hours my guess if this is a unit that has been around a while your breaker has gotten tired replace it. good luck and please respect the electricity disconnect before poking around. good luck
1helpful
2answers
Eaton afci breakers tripping out due to lightolier low voltage lighting. Lightolier and eaton both agree that it is a frequency problem but neither has a solution. Any help?
everytime I plug in my vacuum cleaner (Kenmore canister model) I trip the Eaton AFCI Braf breaker. Now it doesn't even work though I can flip the switch back to the on position
2answers
1helpful
Inside Electric Furnace/Air Handler Not Working. Please help!
ok this can be simple or tricky is the breaker that trips the same size as the one in the breaker panel 2.look in the unit itsself see if there r breakers inside the unit there usually are and they might have tripped it might be as simple as flipping a breaker but the problem with the breaker tripping is what concerns me now it may just be undersized or getting weak and finally crapped out get ur meter and flip the breaker on and see if u r getting power to the unit if ur not u have gott a breaker that isnt letting power go thru now if u have power u might have a bad blower motor turn the unit on and calling for the fan on if the fan doesnt start try spinning the blower by hand now if it starts then u probably have a bad capacitor they r usually mounted on the side of the blower housing it is oval and its gonna be a 5mfd(microfarad) or 7.5mfd and that couldve been what was kicking the breaker now if the blower is stuck and it wont turn or its very hard to turn then make sure the blower wheel hasnt slipped on the shaft and is rubbing up against the housing if it is just loosen the set screw and set it back even and tighten it back up now if the wheel is free and its still hard to turn then u have a bad blower motor its not a big deal to change out and not real expensive if this dont help hit me back and well walk thru it hope this gets lil momma and the pets warm have a good day
Central Air- Breaker flips when AC is turned on
IT SOUNDS LIKE YOU HAVE A BAD COMPRESSOR OR A DEAD SHORT SOME WHERE IN THE UNIT
1helpful
2answers
Circuit breaker tripping from the air conditioner
moter or compresser pulling to many amps on start up you can purchase a hard start kit and also you can ohm out blower moter you could also have a direct short althoug not likly
AC Runs for about 10 minute then trips breaker
is your breaker is ok or lose concation is good.if this both is good than cheek his overload.
2answers
Outside unit tripped the breaker. flip the breaker
Check the fan relay or contacts first. If the compressor comes on then your fan may be locked and will need replacing.
Ac Problems
You must have too many things running on that circuit. Check your connection to the power box.Loose connection on the receptacle can cause the breaker to trip or too many things running on the same circuit. If the breaker is old it might need to be replaced.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Top Dometic Heating & Cooling Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
