Health & Beauty Logo
Posted on Sep 12, 2009
I own a pride victory scooter that stopped working. When I straight wire it from the battery it works; however, wired otherwise it does not work
Will
Level 1:
New Friend:
  • Contributor 25 Answers
  • Posted on Sep 15, 2009
Will
Contributor
Level 1:
New Friend:
Answers
25
Questions
0
Helped
25688
Points
57
Possible blown fuse or breaker needs to be reset.
Pride Victory XL-4 Mobility Scooter
You can get then from Prides website
Wiring diagram for a victory pride 9
Hi I found this type in .google search....,victory 9 wiring diagram ..good luck
2answers
Why does it go-stop-go-stop?
The Controller maybe over heating. another thing that could cause this is loose connection to the battery. Throttle may have broken wire and when you hit a bump looses connection. If you let the scooter sit for 10-15 min. before trying again that could have worked better for you.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
2answers
Controller flashes 9 times what does that mean
Basic Troubleshooting Instructions - Pride Mobility Products
www.pridemobility.com > Resource Center
Pride MobilityINFINFB2468 Jazzy 614/Jazzy 614HD with Dynamic Controller Troubleshooting ... LiftChairs. INFINFB2061 Basic Troubleshooting Instructions: Lift Chairs ...
Pride Mobility Products Corp. - Product Owners Manuals ...
Pride MobilityHelp Me Choose · Where to Buy · Request to Be Contacted · View all Models. Pride Mobility Scooters ... Power Chair Consumer Safety Guide .... Version / Date. Flash. C 01/04. Pride LX Series. C 05/08. Z-11. B 07/04. Manual Wheelchair ... Travel Scooter Throttle Control Lever Operation Product Insert ... Victory 9/Victory 10 ...
Troubleshooting / Repairs Mobility Scooter, Power ...
Where do i find a repair manual for victory 9 scooter
I've never worked on one, but I would remove the battery, and turn the scooter over to see if anything is accessible from underneath. The controller could've burned up. With battery out, check continuity to see where the open is. I doubt it has a computer, probably a just the control panel a speed varistor, and controllers. http://www.monsterscooterparts.com/victory9.html
Manual: http://manuals.monsterscooterparts.com/mobility/Pride/manual-pride-victory-10.pdf
I have a victory pride mobility scooter the battery is fully charged and it won't run I tried to reset but nothing worked
Have the controller module checked. You can also download the service manual from Pride's website. It has a lot of information in it as well as a complete wiring diagram.
Lights work no power
Check you're freewheel lever if its in freewheel u have to take the key out engage lever & put key back in. Also if u have left the key on for more than twenty minutes the circuit will shut down only the light will work. take key out for 5 minutes then put it back it should work unless it's another problem good luck
3helpful
2answers
Battery charger indicating that batteries are fully charged, but battery meter on the scooter shows no power at all. also the lights, indicaters etc arent working, im presuming that is resulting from the...
With a Pride Scooter the charger will turn green if its fully charged and if there is a bad connection in the wiring with the batteries. If you plug in the charger and the light comes on green right away then there is a problem with the wiring or connections. Take a voltmeter and read the voltage at each battery. Fully charged they should be 13-15 volts each. If they are less than 12 volts then they are not charged and the charger is not working correctly. If the batteries are really low like less than 8 volts each then the scooter might not come on at all. If you find that the batteries have at least 12 volts or more then there is a wiring problem from the rear of the scooter to the front tiller. Pride has a habit of developing problems in the harness running from the rear to the tiller. My suggestion is to contact your provider (where you got the scooter) and have them troubleshoot the scooter. If the scooter is less than a year old then it should be under warranty and your provider will have to fix it under warranty. Sorry I don't have a quick fix for you but scooters are notoriously bad to troubleshoot and repair, especially long distance. Hope this helps you
Battery charger not working. A white wire that connects to the AC plug has become disconnected. Can soldering it back on work okay?
yes this is a common problem on a victory scooter i know i have one and the same problem just solder it up carefully
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
