Question about Microsoft Windows XP Professional for PC
Exit acertain game screen goes black with nopmal border
Exit acertain game screen goes black with a small normal edge
  • Douglessd
    Douglessd May 11, 2010
    Which game? There may be a known problem with a solution or work around.
  • 32 Answers
Video card problems
Posted on Sep 13, 2009
SOURCE:
Why does the screen have Black Border around the picture , picture distorted?
There are connectors and circuitry that control the vertical and horizontal picture image generation that need to be at the edges of the screen. The border simply covers these connectors and circuitry so the user cannot see it. Newer models of flat panel TV's solve this problem better to get more picture real-estate to the user. Flat panel TV's are not like the original CRT (cathode-ray) TV's of the past that had borders to conceal a non-linear distortion that occurred at the edges.
Jun 23, 2014 | LG 37LC7D 37 in. LCD HDTV
Screen resolution change = black border around small screen
Once you change the resolution to a smaller size and you see the black border, go into the monitor's menu and there should be settings for the Horizontal and Vertical size/position. Adjust those until it looks correct.
I hope this helps :)
Best Regards,
James
Aug 21, 2009 | Dell Inspiron 8200 Notebook
RIGTH CLICK THEN DISCKTOP THEN PROPERTIES,DESPLAY AD SETTING, CHANGE INTO 1024 BY 768 PEXILS.... TO FIT THE SCREEN RESOLUTION 32BIT ONLY
Jun 04, 2009 | Dell Inspiron 8200 Notebook
Black border around games
Dear milly, so is it clear that this happens on all games or just some? tell me a little more about your system and games you play, I'll try and help. JLS
Oct 18, 2008 | Computers & Internet
Screen problems
Hi...there,
No, it's not normal. It's seems your panel it damaged due to leaked around the edges...
Jan 29, 2008 | Acer AL1716 F Monitor
C840 resolution difficulties...
The type of screen you have is a UXGA screen. the optimal resolution for that is 1600 x 1200. changing the resolution for that will distort the screen causing black borders. If a computer has a 15.0+" SXGA+ screen with an optimized resolution of 1400x1050 and the screen's current resolution is set to 1280x1024 pixels, the display will shrink resulting in a black border surrounding the edges of the screen. Also, all other lower resolutions may be stretched to fit the screen. No border will be visible, but fonts may appear slightly fuzzy.
Oct 03, 2007 | Dell Inspiron 8200 Latitude C840 Laptop...
Picture does not bleed to edge
this symptom is caused by a poor regulation in the power supply circuit. too low dc supply voltage will result to insufficient deflection, both vertically and horizontally. black borders appear around the raster. receivers generally use regulator in the main power supply to set the dc supply voltage at the value that will allow the picture to fill the screen with a little overscan. defective regulator can result in a small raster. most modern receivers today are using ic (integrated cirduit) regulator. but if you are not inclined with this kind of job, better bring it to a qualified tv technician. good luck!
Feb 27, 2007 | Toshiba 27A43 27" TV
Microsoft Windows XP Professional for PC Logo
83 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
