SOURCE: after programming my new universal remote, the tv keeps changing chanels! wont stop!
you need to program your remote control. take the battaries out. and maually turn the tv on. then hit the source you want to view. for example, I want to control the tv set. I push, code search and hold it then push the source button and then release the source button and then release the code search button. now, aim at the tv and then keep pressing power button till it goes off. when the tv is off, hit return or set or something like that.( every remote has different calling for it but still the same function) it should work. try it and let me know.
SOURCE: Tv repair of Samsung standard tv
iI HAVE A 23 INCH SAMSUNG TV THAT IS NOW ONLY SHOWING BLACK AND WHITE PICTURE.HOW DO I GET COLOR BACK?
SOURCE: ORION TV 1926A
I have an Orion Model TV2521. How do I turn on "closed caption" without the original remote? It broke and the tv is now using a universal remote. I tried the onscreen menu on the TV,but did not see an option to perform this task.
SOURCE: toshiba that uses CT-90040 remote
if this is a time warner cable remote. the toshiba code is 015. sometimes a tv has several codes but only one controls everything. dont understand tuning video into tv. sounds like u need to plug rca wire into input plugs on the front or rear and then move switch to video but dont know what wires u r using.
Hi Maureen Purcell, I want to help you with your question, but I need more information from you. Please Call Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7
