SOURCE: Need to disconnect XM Tuner
the xm receiver is in the left rear quarter of van looks like between wheel well and rear of vehicle this is drivers side
SOURCE: 1997 Chevy Cavalier intermittent starting
I had the exact same problem on my 1998 Chevrolet 1500 c/k pickup. I also tried a new starter motor and solenoid assembly, but to no avail.
After weeks of searching for the problem, I found that corrosion had built up between the car battery terminals and the power cables extended from the car battery to the starter motor. I'm not sure if this is your problem, but it's worth a try. Also, check all other electrical connections, because these types of intermittent problems are often electrical.
SOURCE: How to set FM Frequency on XM Radio Delpi SkyFi
is this a skyfi 1 2 or 3. if its a two or three if you go to the menu button and scroll down to fm frequencys and select that from the drop down menu. then scroll through the built in frequencies and determine which one comes in the clearest. if its a skyfi one then your gonna have to put in a wired fm modulator because the first one doesnt come with a wireless fm transmitter.
SOURCE: sirius/xm activation
Typical, they wont recognize sirius and xm on the same account. tyou need to close the old account and open a new account on the new brand head and start from square one. Also - they wont give multi head discounts if you have a mix of siruis branded heads and xm branded heads - each brand needs its own account and own e-mail address. They **** in this regard. Good luck, ive decided between this backwards book keeping and aneed to keep resetting my Sirius head periodicaly that neither is worth the aggrivation so I cancelled all of them.
SOURCE: XM Radio
I would check to see if there has been any damage to the antenna during the installations. You may just need to replace the antenna. Another thing to look at is whether or not the signal is being blocked by any of the new equipment installed. The antenna should have a clear line of sight to the sky. In this case you may need to relocate your antenna. If it continues to be an issue, it could be worthwhile to trouble shoot and see if maybe the dock or radio is causing the issue. If you have other equipment to test out, you can narrow down the issue and find a replacement at tss-radio.com
