Question about Sony Televison & Video
How do I set clock on Sony explode 810 with no remote?
2 Suggested Answers
SOURCE:
jyackle5
  • 8197 Answers
SOURCE: setting the clock on a sony mhc-gx250 without a remote
Og to the link below then click on Operating Instructions. Then on page 10 tells you how to set the clock.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=MHCGX250
Posted on Apr 17, 2010
Set time on sonymp3 cmt-bx20i
You need to use buttons on the remote to set the clock.
1.Turn on the system.
2.To select the clock set mode press TIMER MENU. If the current mode appears on the display, press up and/or down to select
"CLOCK SET?" and then press (+)
3.To set the time. Press up and/or down to set the hour, and then press (+) to confirm. Repeat to set minutes.
The clock needs to be re-set whenever power is lost to the unit.
The clock can be momentarily displayed when the system is off by pressing DISPLAY. The clock is then displayed for about 8
seconds.
The full support section with manual downloads is available here for further help and guidance:
http://esupport.sony.com/US/p/model-home.pl?mdl=CMTBX20I
Hope this is of help.
Dec 17, 2014 | Sony Vertical iPod micro system CMTLX20I...
Request instrtuctions for setting Sony RDRVX560 clock
Do you mean the RDR-VX560 DVD recorder/VCR combo? With the original remote for the recorder, you need to press System Menu (which is the left button on the row of large buttons above the arrow key circle). Then use the arrow keys to select Setup, press Enter and then select Clock Set. (Press Stop before attempting to access the System Menu. Then make sure that the remote is in the same mode as the recorder. The Command Mode for the recorder is set from the system menu as well. The remote can be reset by pressing and holding Enter, then press and hold 1, 2, or 3. Hold both the enter and the digit listed for 3+ seconds.)
To provide more help, I need more information about your Digital Stream remote. I'm not sure if there is a button that will match the System Menu and the Command Mode on your remote.
Remotes.com has a replacement original remote: http://www.remotes.com/store/sony/rdrvx560.html . Other sites may also have the remote for sale.
The documentation for the unit is available from Sony support: http://esupport.sony.com/US/perl/model-home.pl?mdl=RDRVX560&template_id=1&region_id=1&tab=manuals#/manualsTab . The direct link to the manual is http://www.docs.sony.com/release/RDRVX560_EN_ES.pdf .
I hope this helps.
Dec 05, 2011 | Audio Players & Recorders
Setting remote to sony tv
I saw your post, jakegspot1, and I'd be happy to help get that taken care of for you! Try the following codes and let me know how that goes, and if you need any help: 500, 810, 758, 640, and 690.
Aug 30, 2011 | DISH Network IR Remote Control
Setting the clock on a sony mhc-gx250 without a remote
Apr 17, 2010 | Sony MHC-GX250 CD Shelf System
Vcr clock setting
Probably you can't. That's a big pet peeve of mine with A/V equipment these days- so much of the control is by remote only and if it dies your machine is almost useless
Mar 05, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
Changing the time
dvcr-810 series a :steps
1. Press "VCR MENU". The VCR menu screen will appear.
2. Press < or > to select the "SYSTEM SET UP" option, then press ENTER.
3. Press < or > to select the "CLOCK SET" option, then press ENTER.
4. Press < or > to set the month, then press ENTER.
note: To make corrections any time during the process Press CANCEL repeatedly until the item you want to change blinks, then press< or >.
5. Set the day, year and time as in step 4.
6. After setting the clock, date and time starts functioning automatically.
Mar 27, 2008 | Broksonic DVCR-810 DVD Player/VCR
Sony demo
Had the same problem. The display of the home cinema system kept showing "sony demo". I went to the system menu and reset all settings to factory!
Nov 20, 2007 | Sony CMT-M100MD\W CD Shelf System
Setting the clock
Here is a link to the manual: http://www.docs.sony.com/release/MHCGX20.PDF The instructions for setting the clock are on page 10. You will need the remote in order to set the clock.
Mar 13, 2007 | Sony MHC-GX20 CD Shelf System
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
