Dishwashers Logo
Posted on Sep 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Aquarius FDW70 keeps coming up with code A10
Does anyone know what this means and the solution to the problem? Any help will be much appreciated
Anonymous
Level 3:
  • Master 615 Answers
  • Posted on Sep 12, 2009
Anonymous
Master
Level 3:
Answers
615
Questions
0
Helped
228458
Points
2090
Dear sir,
If your dish washer is type EV02 Module,
Error A10: means Faulty fill valve.
Check valve and associated wiring.
If your Dishwasher is
Standard Module + FDW70 + FDW75,
E10 means Heater fault.
Check heater and associated wiring.
i think it helps for solve your problem.
if you have any doubt regarding this issue leave a feedback we will glad to assit you.
Have a nice day
good luck
Dishwasher not doing anything
hi does anyone know what error A06 for the Hotpoint Aquarius FDW70 means and if it can easily be fixed
Jun 13, 2013 • Dishwashers
A06 fault code hotpoint FDW70
hi does anyone know what error A06 means and is it fixable
1helpful
Volkswagon Euro Van engine code INSP? What does this mean
Hi there:
The INSP message means it needs the service system resetting after a service to stop that coming on.
Additionally, I suggest chec this previous answer at similar problem in THIS LINK.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Whirlpool Duet Washer error code A10
Motor Control Unit (MCU)
Heat Sink Thermal Trip
If the thermal protector on the MCU heat sink gets too hot, it will open
the thermal protector on the heat sink which will stop motor functions
and an “F/10” will be displayed.
1. Check for proper installation, verify the unit is not located
near a source of heat and has proper ventilation.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the MCU, the motor,
and Central Control Unit (CCU).
4. Check the drive system for any worn or failed components.
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
1helpful
We have an Hotpoint FDW70 Dishwasher that for some time has had an A10 fault which although stops the machine some times 70% of the time it does a full cycle. However it is now tripping out the electric at...
hi the fill valve triac is the plastic vlave that the inlet hose connects to you can get them for about £10 you reset the machine after replacing it by switching it on, pressing the power button leaving it off for about a minute then switching it back on, and the onboard diagnostic unit resets automatically.
Sep 25, 2009 • Dishwashers
1helpful
2answers
I have washing machine Aquarius wf640 + it keeps showing f-02
F02 indicates that the motor tacho has broken or become detached, this is to be found on the end of the motor shaft.
Pleawse rate my solution.
Thanks.
3helpful
How do i find the float switch for a Hotpoing Aquarius FDW70
Open the DW. Look in the front right or left corner of the tub.
You will see a plastic dome.
The float switch is directly underneath the dome.
Remove the toe kick plate and located the float switch from the bottom.
Sometimes they get stuck.
Jiggle it then try the wash cycle.
If that does not work, replace the float switch.
My aquarius hot point fdw70 comes up with error a10
Check out www.selfix-uk.co.uk for all hotpoint error codes and what they mean
Oct 07, 2008 • Dishwashers
2helpful
4answers
Hotpoint Aquarius+ FDW70 Error Codes
i have the same on my dishwasher and have just been looking on the net. Found out that the error code A10 means open/short circuit fill value traic. Whatever that means!!! and to book a service engineer. Hope that helps
1helpful
Hotpoint Aquarius Dishwasher DWF31
MY DISHWASHER TASTES OF SALT AFTER EVERY WASH .I HAVE RINSED IT THREW AND IT STILL THE SAME
Top Dishwashers Experts
Mike Cairns
Mike Cairns
john h
