After starting my n70 it asks you want offline/online mode. chose online mode and punched the security number and enter then next scree it says sim card notvalid. please help.
Hi, Your phone may be locked to its Network, that's why it shows "sim card not valid". In order to use other Networks, you need to unlock your phone. You can unlock your Nokia N70 using code.You can either get the unlock code from your service provider or from reliable online site. Superunlockcodes.com is where i unlocked my phone, they offered codes at affordable price, with simple unlocking instructions.
IF YOUR N70 IS SHOWING OFFLINE MODE PROBABLY BECAUSE IT DOES NOT READ YOUR SIM CARD OR YOU SELECT YES AT STARTUP. REMOVE YOUR BATTERY AND BRING OUT THE SIM, REINSERT PROPERLY AND STARTUP YOUR PHONE, THERE SHOULD BE A MESSAGE ON STARTUP " DO YOU WANT TO STARTUP PHONE IN OFFLINE MODE?" PRESS NO, (LEFT UPPER KEY) PHONE SHOULD STARUP ONLINE OTHERWISE YOUR SIM CARD IS NOT BEEN READ.
Offline mode means the sim you have inserted was not detected by your phone.Firstly clean the Sim Card slot(case)and check the connector.If the problem still persist contact nearest mobile repairing center. Good luck Visit Again...........Fixya.com
when it turns of in offline mode, turn it off again everytime. after few times, it should ask you before the logo shows up "DO YOU WANT TO CONTINUE IN OFFLINE MODE?" SELECT NO, AND VIOLA. ITS IN GENERAL MODE
getting offline in the sense if u not put ur sim inside the cell it turns to offline mode. and again after v put the sim inside it asks whether to continue in offline or not. u need to give No..try it out..
where did you bought your phone? if you bought it from a telecom's promo it means that your phone is locked to a single network provided only. you can ask a technician to have your phone OPENLINE for you to be able to use any kinds of sims.
if it's not the case, check the slot for sim and make sure that the sim is properly placed. restart it without the sim and then restart again but now with the sim.
