I have an old CRT monitor built on trinitron type technology - the switch that I press has been sort of broken for years. I moved the monitor once and the switch worked for a while, then stopped again. If I get the monitor at the right angle I can get the switch to work. Not so easy for a TV.
You might have the problem that brotherhoodc has suggested. So, perhaps the best option is to get it repaired either way.
Your tv is going into protection mode. It can only be repaired by a tv repairman. The problem is normally the power supply or line out put satge.
I'm trying to turn it on by the tv itself, dont have a remote for it yet. The standby/timer flashes red. Just wont turn on at all. Thank you
A trinitron switch ... How are you turning it on, with a remote control or a switch on the tv itself?
