Refrigerator appears to go into an extended defrost cycle.
Freezer section heats up and defrosts everything in a short time, Melts all the ice . Un plugging it seems to reset it and allows to start to freeze again then a day later defrosted again. Did this about 3 weeks ago then worked ok until today and has defrosted everything again. Has electronic controls. top freezer
Sounds like your freezer has a bad defrost thermostat ( bimetal ) or bad #4 and/or #5 thermistor . This bimetal , has a high temp rating of 140 degrees , which means , when it gets to 140 behind the panel , it will cut off the defrost heater , to keep ice and food from thawing . The thermistors , tell the main control board the temps , and it decides when to restart the cooling process . I would check the thermistors by the digital controls , in the test mode , or have a technician check them for you .
Testimonial: "I would agree with this but how do I get the cover off the defrost thermostat with out breaking it. Also how do I get to the #4 & #5 thermistors? "
I would need your model number to be able to help you more .
To get to the bimetal and thermistors , remove the rear inside freezer panel (maybe 2 screws ) . The bimetal , is the 1" tall cylinder , clipped to the top of the coils , with a pink and blue wire going to it . The thermistor #4 , is the 1" long , white cylinder , with 2 white wires going to it , at the top left on the coils . The #5 thermistor , is at the bottom left , slightly foreward of the drain below the coils , slipped into a housing ( just pulls out ) , with 2 white wires going to it also .
If the top of the bimetal , looks cockeyed , then this is the problem . The thermistors , best to just replace them . Same part number for both thermistors .
The defrost is not
working.This happens due to the evaporator coil in the inner section of freezer is got
blocked by ice .--------
Try manual defrost reset
procedure: ----
First unplug the unit
from main power outlet. Then empty whole unit completely. Then keep both the
doors open. Wait for 24 hours. All the ice collected on the coils and in the
freezer section will get melted. Clean the water from the sections.
Then Connect the power cord of the unit to main power outlet after 24
hours/.Then set the temperature to normal in both fridge and freezer section.
It will take near to 4 hours to get run in its proper cooling cycle. Then check,
if the problem returns again. If the same problem occurs then it's defrost problem.
The defrost board and the defrost thermostat/heater is not functioning properly
and it has to be checked and replaced.
The procedure of this unit
is as follows: --- The compressor starts then it cools the freezer section.
When the freezer reaches its cooling level the defrost cycle starts functioning.
In this cycle the fan in the freezer section starts running and the cool air in
the freezer section is passed to the refrigerator section and the
refrigerator section gets cold. The air from freezer to refrigerator passes
from the section, in that section the damper is located. Now this problem which
you mentioned. In this problem the freezer thaws, this happens if the
thermostat is not functioning or the heater is not heating. Then the ice starts
getting collected on the evaporator coil. The evaporator coil
is at the internal section of freezer. If too much ice gets collected
then this ice blocks the fan in the freezer section from functioning and this
blocks the damper section with ice getting collected there. This all procedure
is controlled by the defrost board of the unit.
So first try reset procedure.If that is not helping then defrost assembly parts are to be checked and replaced.The defrost thermostat is located in the freezer section beside the evaporator coil.The defrost heater is located in the freezer section beside the evaporator coil.And the defrost control board is located in the fridge section.-------------
you
can get the required parts from online sites like:---
www.repairclinic.com or from searspartsdirect online site.---------This will help.Thanks.Helpmech.
How do I get the defrost thermostat cover in the freezer off without breaking it? How do you gain access to the #4 & 5 thermistors? How to test thermistors?
Very good. GE Model PTS25LHPARWW
The thermistors fixed it. Thanks much.
