Question about Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
How to drain the rheem 135 litre tank - Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
  • 1,305 Answers
1. turn off the electrical power first.
2. attach a garden hose to the hose bib attachement on the bottom of the water tank and run the hose outside to allow the water to drain out by gravity.
3. Turn the valve that is on the inlet of the water heater. Now that the power is off, you can drain the tank.
4. open the drain valve where the hose has been attached.
5. To release the pressure, you can open a hot water faucet in your kitchen. This will allow the water to drain out easier.
Posted on Sep 12, 2009
SOURCE:
Rheem electric water heater model 71 305
its for drainage to extend the life of the tank you should drain 2-3 gallons of water every 6 months ... this helps to remove residue from the bottom of the tank
Aug 06, 2014 | Rheem Water Heaters
Do you have to shut off pilot when draining a rheem hot water heater
No.
But if tank is empty for days, you don't want the water heater firing, since it will eventually affect the metal heat-transfer surface between water and flame.
http://waterheatertimer.org/images/Gas-Water-heater-diagram-50.jpg
http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html#air-intake
2) Add comment and say what you are doing.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 24, 2013 | Rheem Water Heater Drain Valve
Drain valve plastic slow leak 81V-80D
If the drip is coming out of drain valve: Put a hose cap over end of drain valve.
If water is seeping out of cracked drain vale, then replace it.
If the leak is seeping around previously sealed threads, then tank may be rusted beyond repair.
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
http://waterheatertimer.org/Leaking-water-heater.html
Oct 06, 2012 | RHEEM 30 GAL ELEC TALL Water Heater 6YR SC...
HOW TO REPLACE THEROSTATE
Twin element indicates you have 220-240Volt electric water heater.
Brand unknown.
135 liter implies European, or Canadian water heater.
Not sure if this water heater uses ordinary thermostat.
Copy following links for resources:
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Sep 04, 2012 | Rheem Water Heaters
Rheem 41v850 leaking at bolt on top
just turn off the gas valve for pilot light, turn off cold water to water tank. drain system. when refilling open cold water to fill tank, wait at least a 1/2 hour to 45 minutes then relight water heater. you should be fine!
Mar 29, 2012 | Rheem 50 Gallon FVR NATGAS Water Heater...
Moved into brand new house March '06. The Rheem water heater has slow seapage/leakeage around bottom. What kind of warranty does Rheem offer? Under 5 yrs of use.
Please specify the exact source of the leak? If it is the tank drain then that can be resolved by replacing the boiler **** valve. If it is the lower element then it may be tightened. If it is the tank itself then you will be faced with replacing it. Sorry, but I am not familiar with the warranty on the Rheem WH. Warranties vary, usual 5, 6 or 10 year.
Dec 09, 2010 | Rheem Water Heaters
Im looking for the drain on a vanguard 3wa79 by rheem. i want to change the element but cant figure out how to drain the tank. i have looked all around the bottom of the tank and around the whole unit and...
The drain is a plastic valve, looks like a knob with a hose fitting coming out the middle of it. It should be about 1' above the bottom of the tank enclosure.
Be sure to turn the gas off before you drain the water and fill the tank before you relight it.
Jun 11, 2010 | Vanguard International Vanguard BY Rheem...
I have a 135 litre, 10 year old Rheen mains pressu...
usually on the hot water piping, It starts to rust closed faster than the cold side, due to electrolosis. What you r discribing are the first signs of this happening. only solution is to replace the effected pipes..
May 20, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Pop off valve dripping Rheem 50 gal electric valve at bottom
If you are reffering to the drain valve at the bottom of the hot water tank. It may be leaking due to the O ring being cracked or worn out. You can either drain the tank and replace the valve or you can buy a hosebib brass cap and thread it on the existing valve. There is no cause for alarm when doing this as this valve is just to drain the tank when replacing your hot water heater
Feb 23, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402 Logo
182 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
Steve Allison
Steve Allison
Sean Lavelle
Sean Lavelle
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
