Computers & Internet Logo
Posted on Sep 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
PMSUER.DAT message on Printmaster Platinum 15
I installed Printmaster Platinum 15 after having hard drive problems. It installed but when I opened receveived message PMUSER.DAT so resolved that problem and tried to reinstall and again the same PMUSER.DAT message. Any suggestions?
  • Anonymous Mar 31, 2014
    Having problems using PrintMaster Platinum, would like instructions.
Alun Cox
Level 3:
President:
  • Master 2,679 Answers
  • Posted on Sep 12, 2009
Alun Cox
Master
Level 3:
President:
Answers
2679
Questions
0
Helped
689381
Points
8444
Have a look here.
http://support.encoreusa.com/kb.asp?id=144
1helpful
My computer crashed, and I am trying to re-install Printmaster Gold 15. I keep getting a box for autodisable, and the install quits. I use ths program constantly, but cannot afford an upgrade. Thanks,...
Thanks for the feedback Carol. Lost 400 files? Whew! If you have lost that much you seriously should consider re-formatteing your hard drive to make sure all traces of baddy have gone. You havent mentioned doing this, so I assume you haven't.
Autodisable stops install on Printmaster Gold 15
Not sure why this came up again. Thanks for the feedback Carol. Lost 400 files? Whew! If you have lost that much you seriously should consider re-formatteing your hard drive to make sure all traces of baddy have gone. You havent mentioned doing this, so I assume you haven't.
Our business has been using Printmaster 15 for a few years now. We recently bought a new computer with windows 7. Printmaster 15 is obviously not compatible with Windows 7. I bought printmaster 2011...
You can try version 15 in compatibility mode:
Troubleshoot Compatibility
This can help with some (but not all) programs/drivers:
1) Uninstall the program if it's already installed. Then when you install/reinstall it instead of double clicking on the install file right click it and select "Troubleshoot Compatibility"
2) Then click "Try Recommended Settings" and in the next window click "Start the Program" to install it.
3) After it installs see if it works correctly. Please note - some programs may not be able to run in Windows 7.
More details about how to make older programs run in this version of Windows:
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
I have vista, tried to install printmaster 15, did not completely install, and now i cannot uninstall the printmaster program so that i can try to install it again.
Here is a link to their website which describes how to manually remove the software from the hard drive. Let me know if it doesn't work and we can try some other options.
http://www.broderbund.com/c-26-support.aspx
I recently had my computer serviced for a major virus attack. System operates on Windows XP. I now cannot open PrintMaster Platinum 12. I get a message "cannot determine configuration." Additionally, I...
May have to uninstall it first, then reinstall it.
Click START button, lower left corner
then click Control panel
then click on add or remove programs
*see if your product is listed(may be under BRODERBUND or other publisher name)
If it IS listed, uninstall it
Or sometimes the UNINSTALL is included in the CD options:
Insert the cd into the drive
go to my computer
find the cd drive
right-click the drive
select "explore"
Look for an Uninstall program
Hope this helps!
hansola
1helpful
Uninstall PrintMaster Platinum 15 but have to reinstall access de
Make sure you can see all the files. (My computer --> Tools --> Folder Options ---> View (tab) --> <Select 'Show hidden files ...' option.
Find the folder you have indicated. C:\DOCUME~1\Jan\LOCALS~1\Temp\{A35C2323-3CEA-405C-9569-EF5DDE930B2F}
Delete that flder.
Restart the computer and reinstall the software.
I recently uninstalled Printmaster Silver 12 (temporarily needed all the hard drive space I could get), and now I am trying to reinstall. The install process gets to the registration phase, gives the...
Most programs like this leave behind "junk" files or folders with some information in them.
Try uninstalling it again, then go to the C:\ drive and look for any folders that it might have left behind.
Then go to Start do a search for PMUSERS.dat and delete it.
3helpful
2answers
I have a error message when trying to open printmaster platinum 12
Use window search find the file and delete I did what was at support and it did not work I found this file in all users folder deleted it and all is well
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
