Check the link -- if this is the correct device page 44 of the first english manual has the code for changing the confirmation page setting.
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Plain-Paper-Fax/Copier/model.KX-FG2451
Hit the function button, then # 7, then #4. Scroll down to fax parameters until you come to print confirmation page. To turn it on push # 1 for yes.
SOURCE: Fax does not print a confirmation page.
Use Function 8 not 6 and use set to lock it in. Lawrence
Directly from HP's manual on this printer:
Send a basic fax
You can easily send a single- or multiple-page black-and-white fax by using the
control panel, as described here. If you want to send a color or photo fax, see the
onscreen HP Image Zone Help.
Note If you need printed confirmation that your faxes were successfully sent,
enable fax confirmation before sending any faxes. For more information, see
Print fax confirmation reports.
Tip You can also send a fax manually from a phone or by using monitor
dialing. These features allow you to control the pace of your dialing. They are
also useful when you want to use a calling card to charge the call and you
need to respond to tone prompts while dialing. For more information, see Send
a fax manually from a phone or Send a fax using monitor dialing.
1. Load your originals, with the print side up, into the document feeder tray. If you
are sending a single-page fax, such as a photograph, you can also load your
original on the glass.
Note If you are sending a multiple-page fax, you must load the originals
in the document feeder tray. You cannot fax a multiple-page document
from the glass.
2. Press Fax.
For more assistance with this printer, you can go to http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=441125& and download the owner's manual. It is in PDF form, so you will need adobe reeader which you can get for FREE at http://www.adobe.com
Rose Marotta
PC ICU
Danville, Va 24541
For all your computer repair needs.
How do I program to receive a confirmation page with each fax I send?
same problem. do not get a confirmation page after sending fax
