Zanussi 24 in. DE6744S Free-standing Dishwasher Logo
Posted on Sep 11, 2009
Where is the drain pump located on zanussi dishwasher model DE 6744 S ?
Anonymous
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Aug 04, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
18
Questions
0
Helped
4253
Points
37
The Drain pump can be got to by removing the circular filter at the bottom of your machine and all the screws that hold the plastics in including the round retaining plastic clip, only then will you see your drain pump prepellors, but if you want to remove the Drain Pump then this can be done from the rear of the machine you might have to remove the macine outside for this as you need to turn it on its side, from the back of the machine remove the two screws holding the big electronic motor this is plugged into electric sockets remove them also there is a rubber bung that holds this in place once unscrewed the motor needs a bit of a jig and it should slot out through the back of the machine. If you are thing of changing this it costs about £120 I got rid of the machine myself.
1helpful
The power is on the cycle light is on but on the right the first two lights are flashing together. help zanussi aqua pulse de 6744 s
Hi, the first thing the dishwasher does is fill with water, so this sounds like a Anti Flood water pump problem this is just behind the water pipe that feeds the clean water into your machine, one thing to check is if the machine is empty of water at the moment, if the machine has water in the bottom then it could be the Drain Pump.
1helpful
The dishwasher runs, but never seems to wash the dishes!
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Concerning the drainage issue(left over water at the bottom)
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Frigidaire D/W. Model fd8750rcc0
hi Dishwashers usually run on 115-volt or 120-volt power. The water they use comes directly from the water heater, and wastewater is drained into the sink's drainpipe. The dishwasher is not connected to the cold-water supply. For best dishwashing results, set the temperature control of the water heater to no less than 140 degrees Farenheit. Water cooler than this usually doesn't get the dishes clean, unless your dishwasher is a newer model that preheats incoming water. The water shutoff for the dishwasher is typically located below the adjoining sink.
1helpful
WATER NOT HEATING IN MODEL DE 6850 Zanussi DISHWASHER
YOU NEED TO LOCATE THE THERMOSTAT AND CHECK IF ITS WORKING CORRECTLY IF THE READIND ON THE STAT IS FINE YOUR ELEMENT MIGHT BE FAULTH.BEST YOU GET A TECH TO ASSIST YOU AS ITS A TUFF JOB TO DO ALONE.
GOODLUCK.
MOHAMED
Zanussi DCS12w Not draining - Pump location needed.
It is inside the cabinet of the dishwasher, pull it out if build in to see the pump.
Zanussi DE 6965
Hello Russel A L 6 Is Water Drain Time-Out Possible causes are; a) Domestic drain outlet unsuitable (obstructed) b) Motor faulty (pumps group/ drain impeller) c) Pressure switch faulty d) IWMS- Pressure switch tube obstructed e) IWMS- Sump vent hose obstructed f) Control board (Relay interrupt Regards David Marsh
3helpful
2answers
Zanussi built in aquasave zt 685
I think I had a similar problem to this. It seems like it was starting a cycle but then it just stalled and made a buzzing noise and it did not drain properly. I opened the bottom of the dishwasher where the draining pump was located. take off the plastic cover and I found bits of broken plates were jamming the fins on the pump... Try this and see how it goes.. Hope it was of some asistance.
Top Zanussi Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
