NorStar M7310 Corded Phone Logo
Anonymous Posted on Sep 11, 2009
I have the same problem: mailbox locked
An employee left, tried to clear mailbox for new employee; mailbox locked; understand all the steps to unlock, except do not know how to "log in" by system administrator. I have the "config" and "6623" password, but it asks for administrator's mailbox and pw... I do not know what the system administrator's mailbox is??? I tried the main unit which is 7300, but that did not work either. I have two people whose mailboxes are locked and need to get them unlocked!!!!
  • 3 more comments
  • Anonymous Sep 14, 2009
    That did not work. I used both "LOG" numbers you listed and both of them state "invalid password".
    This did not work either. It did say it reset my password, so the second part of your instructions worked, but when I repeated the first part of your instructions, it still says invalid password... our extensions are 7319, 7821, 7322, etc... does that make any difference
    Just a little more help!!! That worked!!! but default password will not work (0000)... it says password must be changed! But it did unlock the mailbox! I am so excited and SOOOOOOOOOO THANKFUL FOR YOUR HELP.... One more time, please?????
    NEVER MIND IT WORKED!!!!!!!!! GOT PASSWORDS RESET BUT CANNOT UNLOCK MAILBOX ON MAIN UNIT...7300...SAYS INVALID MAILBOX... IS THAT BECAUSE IT HOLDS THE AUTO-ATTENDANT, ETC? ALSO, I am the one who set up the auto attendant, and with 2 new people, I need to add two more but forgot how. Is this too difficult to help me with. I previously set up the night ring, day ring, etc. I just need to add "for _____ please press 5" for ______ please press 6"???? THANK YOU. THANK YOU.
Anonymous
Level 2:
  • Expert 192 Answers
  • Posted on Sep 11, 2009
Anonymous
Expert
Level 2:
Answers
192
Questions
Helped
239376
Points
557
How to Change a Mailbox Password (Administrator Only) 1. To access the voice mail system press "Feature".
2. Press "983".
3. When you see "Log:" enter "120000" for 2 digit extension numbers, enter "1020000" for 3 digit extension numbers.
4. Press "OK".
5. Press "MBOX".
6. Press "CHNG".
7. Enter the mailbox number (same as extension number) you wish to reset.
8. Press "Reset" softkey.
9. Press "Rls" to exit (orange button to the right of the number buttons).
The Default password is "0000".
Testimonial: "It did not work. When logging in as administrator with the numbers you gave, I only receive "invalid password""
  • 5 more comments
  • Anonymous Sep 11, 2009
    This will also unlock their phones...
    Sorry forgot to mention that too!
    Good Luck
    Sorry about the delay, I never knew you responded...
    How do I reset the Operator Status password on the Norstar Voice Mail
    System?
    Press Feature and enter 985 on the telephone dial pad.
    Enter 9.
    Enter 73738767793 (RESETSMPSWD)
    The display will show Reset OK. Choose YES on the softkey.
    Once this is done, this resets the password back to 1020000 ro 3 digit extension numbers, or 120000 for 2 digit extensions. Afterwards try my original instructions.
    Good Luck
    oh if you have 4 digit extensions your LOG in is 10020000
    I should have caught that on the original post, my bad!
    after you change the default password for the individual set, the system will ask you to change the password to something else, because it wants you add the security feature of non-default passwords.
    Change the password to something you can remember... like 7887 or 1234 or 1379... anything will work.
    But if there are issues again, you can aways go back and default the password.
    This is more common than you think in most companies.
    Have a great day!
  • jenncarper Aug 11, 2011
    I get that far but then when i go to that mailbox number it still tells me mbox locked contact admin. I am the ADMIN!!
  • Anonymous Dec 26, 2012
    pLEASE LET ME KNOW IF YOU GET PAST THE MBOX LOCKED CONTACT ADMIN!
1helpful
2answers
Vodavi mailbox password reset
First, access your voice mailbox (press VM button & enter your password)
When you hear you have ??? messages, Press 7.
You will be prompted for another password (the Admin default password is 2275)
Press 2 administer mailboxes
Press 1 to reset mailbox password then follow the instructions. It will tell you what the current password is to the mailbox you select and you have the option to keep it or change it.
3helpful
Employee forgot his password and need to change the voicemail for new employee. Is there a way to reset the phone. Phone model is a Superset 4025. My phone number to the phone is (563) 690-3230 or email...
Each mailbox password is held in the system programming of the voicemail system. You need the system admin password for voicemail. Dial the access code for voicemail, if from a phone with voicemail then press * to get to the main greeting. At the main greeting dial * then the system admin mailbox number which is 99 for 2 digit ext numbers or 999 for 3 digit ext numbers or 9999 for 4 digit ext numbers then you will be prompted for the system admin passcode(default 1234). Press 2 for add/edit/delete (Never press 1 for new installation or you could delete all current voicemail programming and messages). Press 2 to edit mailbox, you will be prompted for the mailbox to edit, enter the mailbox number. Press # to skip to the passcode reset, enter the new passcode or press * to reset to default(999) then press # for each of the remaining parameters until you are returned to the mailbox menu which prompts for press 1 to add mailbox, 2 to edit mailbox, and 3 to delete mailbox, then hangup.
Need to change password on voicemail extension on
If it's a Panasonic brand voice mail, you administer the system from the System Owner's mailbox (999). With that, you can use option 4 or 5 and reset the mailbox password to any and all mailboxes (except 999 :-)
Carl
1helpful
PHONE LOCKED ON T7316E
To reset a subscriber mailbox press feature 983, enter in log (default 1020000), on the 3 soft keys bolow the the screen press mbox,chng, enter extension number of the locked mailbox, press reset at the reset password prompt.press rls key
I have a Partner-18 and need to reset the password for a user
Delete the mailbox for this extension then re-create entire mailbox.
Need to set up user voicemail box (new employee)
Go back to your vendor and get the password for mailbox 999 and the instructions to log into it.
The mailbox exists or it wouldn't ask for a password (they're assigned by default), so you need to go to mailbox 999 and chose option 6 1 3 which is mailbox administration reset password. That will clear the password and you can log into the voice mail automatically from the extension by dialing the voice mail access code.
Post back if you have any problems.
Carl
How to set up password for voicemail/how to set up new mailbox
By default, a Panasonic TVA voice mail system can have a password set. It could be 3 plus the extension number, but it doesn't matter. You can clear it by logging into mailbox 999 and going to options 6 1 3 which will be the mailbox password menu. Select the lady's extension and follow the instructions to confirm password deletion.
Now she can call voice mail from her extension and set a new password.
This also works for a TVS system.
Carl
2helpful
Employee's mailbox locked and No one knows Admin password
Jessie711 - You Rock! Your post on the 21st fixed my problem :)
Oartner ACS - Voice mailbox
If you go into system admin in voicemail, you have to edit the mailbox and give it a name.
intercom 777, 0#, 123456#, 9, 4 (mailboxes) enter the mailbox number and follow prompts to change the name.
WWW.telemanuals.com
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
