Garden Logo
Dominick Giusti Posted on Jul 27, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bobcat ToolCat won't go into forward or back. The hydraulic loader works though?
ADMIN Andrew
Level 3:
Top Expert:
  • Bobcat Master 66,963 Answers
  • Posted on Feb 15, 2024
ADMIN Andrew
Bobcat Master
Level 3:
Top Expert:
Answers
66963
Questions
Helped
5085923
Points
379812
1 Related Answer
Anonymous
  • 90 Answers
  • Posted on Sep 01, 2010
SOURCE: Hilti-284228-rw-98091-163317
to my knowledge you have to send it to a hilti service center. you can't buy parts nor can a local shop buy parts for them. you may just have a loose wire or the switch you move to change direction may have come loose inside.
1helpful
2015 Bobcat T770have an error code m0721 hyro temp to high bobcat said change temp sender where is the sender located?
the hydraulic temperature sender is typically located near the hydraulic oil cooler or the hydraulic tank. It may be mounted on the side of the oil cooler or tank, or it may be mounted on a hose leading to or from the cooler or tank.
Dec 03, 2022 • Bobcat 773
How do I reset the service alert after an oil change for a bobcat toolcat?
The bobcats I have worked on do not have this feature.
Bobcat oil change hours reset
https://www.youtube.com/watch?v=vRMyylISKlc
Better sound
How to Reset Oil hour meter on a e50 Excavator The Bobcat Guy
https://www.youtube.com/watch?v=ueDKdAenZkU
Reset Service Interval - Quick Tip
https://www.youtube.com/watch?v=gMl0jSx_1Kw
2answers
Bobcat toolcat error code 50-67
servo coil under current
Anyone have auxiliary hydraulics layout particularly where/how its plumbed into control valve
PDF]2013 Skid Steer Loader Parts - Tractorpartsasap.net - All ...
www.tractorpartsasap.net/.../2013_Skid-Steer-Loader_Parts-Catalog.pdf
Auxiliary Heaters . ... Hydraulic Lift Cylinder . .... Service Manual - Tells you how to take the skid steer apart, how to fix it, and how to put it back together ... in the serious repairs or restoration, you need the shop service manual; It can give you many ...Bobcat. 520, 530, 533. 122571. $48.00. Bobcat. 500, 600, 610. 122521.Missing: layout ‎plumbed ‎into
[PDF]PARTS REFERENCE GUIDE - Service Motor Company
servicemotor.com/catalogs/PM-8490.pdf
HITCH PARTS. 125. HYDRAULIC PARTS ... Find the same heavy-duty quality builtinto Case IH batteries for your truck ... lawn and garden tractor, Case IH has the ... Whether it's off-road, lawn and garden, automotive, or marine application, look ...... 12 Gauge. Aux. Lead, 3/8" Eye with B- Splice 12". ZQC708101. 4 Gauge.Missing: layout ‎plumbed ‎1977 ‎clark ‎520
Massey Ferguson Tractors Information - SSB Tractor Forum
www.ssbtractor.com/wwwboard/messages9/
What hydraulic fluid is needed for a Massey Ferguson 390 · MF135 Selling ...... Hydraulics quit working after installing Aux Hydraulic control valve. MF 135 lift
Case Farm Tractor Parts and Manuals - Yesterday's Tractors
Dec 12, 2015 • Garden
How do you bleed the hydraulics on a Bobcat 751 skid steer loader?
Hi Joseph:
Usually hydraulic components will "self clear" any air in the system just by trying to cycle through the functions a few times.
Have to ask the question............
Did you remove and replace the hoses one at a time, or did you take them all off at the same time?
The reason I ask is............ Could there be a remote possibility that any of the hose onnection locations were switched?
Sep 23, 2015 • Toys
1helpful
3answers
I have a bobcat s175 the bucket will not stay tilted up it slowly goes back down
Most likely a control valve is leaking. If it just comes down over a long period of time that is not unusual. Most all loader buckets will slowly drop when parked in raised position.
May 31, 2015 • Bobcat 773
Bobcat 641 skidsteer hydraulic problems.
That's one of the first things that came to mind as I was reading through your post; that the system was air-bound. Are there bleeder valves on the system?
In any event here is a website where you can buy the service manual for your skidsteer; https://mypowermanual.com/shop/bobcat/bobcat-641-642-643-skid-steer-loader-service-manual-download-6566135-10-86/
2answers
773n bobcat will move forward and back but wont raise bucket
Bics coil on control valve not unlocking. Broken wire, bad connection or bad coil
3helpful
4answers
Top Bobcat Garden Experts
john h
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Bobcat Garden Expert? Answer questions, earn points and help others
