Question about Exercise & Fitness
Hi I am looking for Manual on Treadmill Healthstream Elite Series ES2500
4 Suggested Answers
6ya staff
SOURCE:
jklisiewicz
  • 246 Answers
SOURCE: I have a healthstream treadmill model LS3T and it
if you take the motor shroud off the front of the treadmill, you'll find wiring and connectors. check them and make sure none are loose, cracked, corroded, pinched, rubbing, or frayed and touching metal. also check under the display, there should be an access panel you can unscrew and remove to check the connections in there as well.
Posted on Feb 17, 2010
JIm Shipley
  • 218 Answers
SOURCE: how can fix my healthstream LS720T treadmill?
You will need to check the speed sensor for proper alignment and function. it should be located near the front roller or mounted on the motor. It should be within a credit cards width of the magnet or toothed wheel. If properly adjusted check with an ammeter to see if it is opening and closing by manually spinning the front roller or motor flywheel. If it isn't replace the sensor. If it is functioning make sure you are getting 5vdc to it across the wires. If you are not replace the upper control board(console). If you are getting the proper voltage then replace the lower control board(motor controller).
Posted on Aug 11, 2010
Testimonial: "awesome!!!! just briliant.........i just follow the procedure do a bit of adjustment then presto!!!problem solved !!!! thanks a lot !!!!!!!!!!!"
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: I have a T802 Healthstream treadmill that has an error 2 on it? Can't clear it.
follow this steps and fix it. God bless you
Instructions
    • 1 Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
    • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3 Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4 Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
Posted on Oct 16, 2012
Manual for the Healthstream treadmill EVO 205 T
Google (Healthstream)(EVO 205 T)(manual) without parens.
Jun 30, 2018 | Exercise & Fitness
Where do I find a manual for a evo8000 healthstream treadmill?
www.manualsonline.com
If you wish to get some details ; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Dec 31, 2016 | Exercise & Fitness
How do I fix E7 error message on Healthstream Elite treadmill?
If you wish to get some details about treadmill error codes; check the site linked here. Pull up older posts.
Aug 04, 2016 | Exercise & Fitness
Healthstream manual I have a GE3400T healthstream
go please to www.fitness.manualsonline.com or www. retrevo.com
and download for free.
God bless you
Oct 31, 2013 | Exercise & Fitness
Healthstream GS1165T treadmill, where do I have to lubricate it, i have lost the manual
see the video and proceed according. lube the rollers bearing front+back +drive belt motor test , and replace the belt if necessary.\\God bles you
Jul 05, 2013 | Exercise & Fitness
Where could I find MARQUEE MB203 EXERCISE BIKE instructions booklet
Hi i need a manual for healthstream exercise bike marquee series MB 203.
Mar 16, 2013 | Exercise & Fitness
Error E6 on Healthstream treadmill
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts.
Mar 16, 2012 | Exercise & Fitness
Owner manual for Impuls T790 Treadmill
Hope this is what you need.http://www.healthstream.com.tw/upload/2011/01/20110128111522.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Sep 15, 2011 | Nordic Track Nordictrack Exp 1000...
I need a owners manual for my cardio zone treadmill we bought it and did not get a manual
You have a Horizon Elite Treadmill.
Owners manuals can be found at
http://www.horizonfitness.com
look under customer support, archives/manuals
Dec 15, 2010 | Elite Exercise & Fitness
I have a healthstream treadmill model LS3T and it has just come up with a fault ER01 which the owners manual says is a communication error. Where should I start looking
Feb 17, 2010 | Exercise & Fitness
Exercise & Fitness Logo
46 people viewed this question
Top Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
ray gallant
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
