Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
WILL NOT BUILD UP AIR PRESSURE PAST 20 LBS.
RUNS FINE, BUT WILL BOT BUILD UP PRESSURE PAST 20 LBS. WILL JUST CONTINUE TO RUN AND RUN. THE FILTER IS MISSING, WOULD THAT HAVE ANY IMPACT?
    President:
  • 1,730 Answers
Check to see if air is leaking past 'pressure relief' valve. It's probably leaking and that's where all the air is going.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 11, 2009
6ya staff
SOURCE:
Why wont my steelcraft 13 gallon 5hp model ta25 build up no more then 20 pound of pressure and all i did was change the oil?
Check all connections for air leak including the water drain valve with soapy water. If no air leaking from connections, spray soapy water on head area where head attaches to the cylinder checking for gasket leaks. If no leaks are found, most likely problem is in the head /valves /internal gasket leak. If head gasket or valves are leaking, you will notice that air seems to blow out of the intake filter (normally there is good suction at the intake). Good luck
May 16, 2014 | Air Tools & Compressors
Compressor runs and sounds ok, but it only manages to show 20 lbs. It will not build air pressure and continues to run.
check air tank drain valve located on bottom of tank, if it is not leaking try adjusting air pres regulator (large black knob close to air hose connection.) the knob when turned in will increase the tank air pressure, if knob wont turn check that lock ring on bottom of knob to make sure it is disengaged. also check for air leaks in all lines and connections
Apr 16, 2012 | Craftsman 1 hp Air Compressor, 4 gal. -...
My compressor will not go over 20 psi i have a craftsman 921 4 gal 125 psi compressor and it will not build past 20 psi i do not know how to get to the pistons and stuff what do i do?
The problem with compressors not building pressure is usually a bad pressure switch or bad regulator. Does the motor shut off at 20psi or does it continue running and not build pressure? If the motor continues to run with no increase in pressure, the you should go over the machine looking for air leaks from your regulator back all the way to the motor. Any air leak while the compressor is running can cause the pressure to "peak" way before the intended shutoff that it is regulated to.
Mar 01, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a bostitch 6 gal pancake compressor that won't build pressure past about 20 lbs. when I turn it off I don't hear air leaking out anywhere and when it's running it runs at a higher pitch ( similar to...
I'd pull the cover off to expose top of cylinder head and have a look at any intake air filter. In parts diagram, It appears there is a small one that would likely clog during the texturing process.
Jan 26, 2011 | Stanley Bostitch CAP2060P 105 Amp...
Pressure will not build up past 20 PSI
It is possible the reeds in the intake are loose. This requires removing the top of the cylinder, not for amateurs as the bolts need proper torque and the crack easily. Also check the cold start valve, it is a small brass valve with a needle in the center it bleeds air for cold starts, should be on the tank if so equipped. Check the unloader too. Run the unit then shut off the motor at 20 lbs and listen for air leaking. Not hearing air leaking would indicate the first suggestion of reeds or if it is old, worn rings.
Dec 24, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a 5 gal, i hp craftsmen compressor, 3 years old, used once a year to blow down sprinkler system. Compressor ran up to 120 lbs upon turn on, would not cycle off. manually shut off unit and turned...
Oil free pumps do tend to blow the piston ring (not too expensive) available at searsparts.com. Remove covers to pump and manually turn crank until piston is at top and look at the condition of the cylinder neer top, If it looks scratched, order cylinder kit with piston ring. If it looks good and shiney, could be the valve plate in the head. There are reed valves that tend to break. Run pump however with covers removed and check with soapy water for air leaks and repair as needed (air leaks under the cover will prevent unit from filling). Good luck
Nov 13, 2010 | Craftsman 15 gal Air Compressor 3 hp UMC...
AIR PRESSURE PROBLEM
The issue suggests that the head gasket is blown between the two cylinders or the reed valves are not seating or broken. The only other condition that would cause this is a leak. Here are a couple of simple tests. For leak spray soapy water on all connections and fittngs including the pressure regulator and the bottom of the pressure switch while unit is running. Repair as needed. If no leak is found, run compressor untill it reaches 60 or stops increasing and feel for suction at the air filter intake. The best way to check for suction is to remove the air filter and feel for suction at intake port-hole. The suction should be very strong. When valves are leaking it almost feels that the air is blowing out thru intake. If little or no suction, remove head and valveplate and replace parts as needed. Parts are available at www.chpower.com or www.toolpartsdirect.com. Good luck and post again if you have other question.
Jul 28, 2010 | Campbell Hausfeld 5HP 20 Gallon Single...
Tank will not build pressure beyond 25 lbs. Just runs
IS YOUR AIR FILTER CLOGGED. SOUNDS LIKE THE VALVES IN YOUR HEAD ARE NOT CLOSING ALL THE WAY. THEY ARE MOST LIKELY REED VALVES, THIN STRIPS OF METAL THAT OPEN AND CLOSE WHEN THE PISTON MOVES. MAKE SURE THEY ARE CLOSING ALL THE WAY (NOT CARBONED UP). DID YOU REMOVE THE HEAD AND DID YOU PUT BACK LIKE YOU FOUND IT - NOT TURNED OR FLIPPED OVER. SEE IF YOUR FINGER WILL GET SUCKED UP TO THE INTAKE HOLE.
Apr 12, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
853 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
