Proscan 32LA30Q Television Logo
Posted on Sep 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there anyway to hook up external speakers to the tv? Like a surround sound system? computer seakers?
  • Anonymous Mar 28, 2014
    Can I turn on external speakers?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 21, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2069
Points
There is no audio out in my proscan 32LB30Q tv so there is no way for me to hook it up on my amplifier....
Anonymous
Level 3:
President:
  • Master 3,085 Answers
Anonymous
Master
Level 3:
President:
Answers
3085
Questions
Helped
1006363
Points
9738
The easiest way is to look at some TV SOUNDBARS. Boston Acoustics makes excellent ones.
Hook mz506 surround sound to my Samsung tv
Typically surround sound is run through a receiver or stereo. The sound from the tv is carried to the receiver by cables (hdmi or Audio-Video connected to input area of receiver). Then the speakers are connected to the output area of the receiver.
If you are not using a receiver, then the speakers must be able to connect directly to the tv and you have to see what kind of cabling your tv supports.
No audio. good video
Not familiar with this make of TV, but some TV's require you make a change to the audio menu from int. to ext. speakers. Do the internal speakers work and if they do, besides the menu change are you useing an external amp with your surround system?
1helpful
2answers
Can't figure out why there isn't an out on my curtis mathes for surround sound with sub. When we bought the "tv" from a friend we thought it was a "flat screen tv" it says on...
In most cases the TV is used just as an input device, and they frequently have no output jacks. Usually the TV is hooked up as part of a home theater system, and is used as a video monitor while the sound is taken care of by a receiver or amplifier. The sound comes from the video source (DVD player, set-top box, etc.). Some TV sets have audio output available, but it sounds like yours doesn't. If you want to have surround sound, you'll need to invest in a receiver and speakers.
Hooking up external speaskers to my Panasonic TV
you will need to buy a surround sound receiver. the new tv's do not have an external speaker jacks on them. you might also try a old stereo receiver hooked up to the tv's audio out jacks
How to hook up additional speakers to the TV
If you have a surround sound system, (amplifier and speakers), run the DVD speakers out wires to the amplifier IN. Thi way, you don't even need the TV speakers.
2helpful
3answers
I need to hook up this system to my tv.... thanks
you want to install your TV sound thru this Surround sound system ?? let me know
2answers
HTS-GS1 Surround Sound System cannot be utilized for tv.
Check Your TV audio setup,many TV makers out there would like you to turn off the tv speakers in order to use the external speakers.
Joe
3helpful
2answers
Sony surround sound hookup
In short, the answer is: Hook up all three to each other. I have a Samsung DLP HDTV, and I was trying to hook up a Sony DAV-HDX500 home-theater system and a Comcast HD set-top box, but I found that the Sony user guide is helpful only for setting up the speakers. Most of what it had to say about HDMI and getting the TV sound or cable sound to go through the speaker system was wrong (or, at least, it didn't work for me). So, here's what I did. I connected Component video cables (Y/Pb/Pr out) from the Cable box to the TV (Y/Pb/Pr in), audio cables from the Cable box (audio out) to the Sony system ("SAT/Cable" audio in), and an HDMI cable from the Sony system (HDMI out) to the TV (HDMI in). This allows me to 1) watch DVDs with surround sound through the TV's HDMI source (when the "DVD" format is selected on the Sony system), 2) watch cable with surround sound through the TV's Component source (when the "SAT/Cable" format is selected on the Sony system), and 3) watch cable WITHOUT the surround sound, as I did before I ever had the Sony system. One item of note: When watching a non-HD channel with the surrond sound on, the audio is slightly out of synch with the video; thankfully, there's no such problem on HD channels. Anyway, I hope this helps. It drove me crazy for two days straight!
2answers
Connecting a logicK TV LCX2 to a Yamaha Surround sound system YSP 1
Not entirely sure what the problem is. You should have Two RCA outputs (left and right) from the TV. These plug into the surround decoder, it decodes the dolby and provides 4 or more outputs for speakers. If I have misunderstood you then please comment before rating badly
Top Proscan Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
