F23 is flashing on the display panel any idea what this means?
F:23 means that your machine is leaking and should be repaired. This is often a bad seal and if you are competent or know a friend who is they can inspect the source of the leak for you. Needless to say you should make sure that you unplug your machine before attempting any repairs.
Hope this helps you.
Hi
F: 23 means that your machine is leaking and should be repaired. This is often a due to a bad seal.You need to unplug your machine to check for any leak.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
