Microwave Ovens Logo
Ivan Shapiro Posted on Jul 26, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sharp Carousel Microwave Model R-8680A The touchpad beeps (and the unit responds) but there's no display (blank screen)
Lollo Pop
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 134 Answers
  • Posted on Aug 05, 2019
Lollo Pop
Expert
Level 2:
Cheetah:
Answers
134
Questions
0
Helped
73717
Points
301
Needs a new screen. May be uneconomical to repair.
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jul 04, 2008
SOURCE: Sharp Carousel Model R9H84B
I've attached the portion of the manual which shows how to lock & unlock this model.
If that doesn't work, unplug the oven for one minute, plug it back in aga9in, then try again.
If it still doesn;t work, then your keypad has failed, and they are no longer available for these model, so the oven would have to be retired.
Good luck.
We're happy to help and we appreciate your thoughtful rating of our answer.
Anonymous
  • 38 Answers
  • Posted on Mar 15, 2009
SOURCE: Hi our Sahrp Carousel microwave LCD panle display is not working
You have to replace the control board. Sharp has had problems with the display boards for awhile. There is no bulb or fuse you can change.
Anonymous
  • 456 Answers
  • Posted on Aug 16, 2009
SOURCE: Looking for instruction manual Sharp \carousel
if you google the model number and the brand you should be listed with a series of sites that supply manuals, service manuals, etc.
Anonymous
  • Posted on Dec 14, 2009
SOURCE: Wattage Sharp Microwave Ovens Carousel Model R-3A35
i just checked my R-3A36 manual to find out the wattage. it's 800 watts. i make pralines in my microwave. i am always asked for the recipe. so i needed to be able to tell people the wattage of my oven so they can adjust the recipe to their oven.
garry, metairie,la.
Anonymous
  • 1970 Answers
  • Posted on Jul 07, 2010
SOURCE: User Manual Needed for Sharp Carousel Microwave Model R-303CW
mcdevito75 here, Best Bet, contact Sharp online, try sharp microwave oven.com Or in any store that sells Sharp microwave ovens get contact info off that package.
3helpful
Sharp Carousel Microwave - R1481 keypad doesn't work
No! I'am afraid not, the problem is in the keypad control board, the whole assembly must be replaced, the part alone will cost around $100.00 or more depending on make and model.
2helpful
R-8350, No power to touchpad, but interior light works
The touchpad has its own fuse which has probably blown due to a surge perhaps related to the turning on of the fridge. Removing the cover from a microwave is potentially lethal due to the large capacitor to drive the magnetron. However, this is usually well away from the front panel. If you do venture in you should first unplug the unit and when the outer cover is removed, discharge the large capacitor with well insulated pliers -= otherwise keep well away from it. The fuse you are interested in is on the pc board behind the touchpad. Replace it with exactly the same fuse (usually a slow blow fuse).
Sharp Carousel Microwave R-1505
There are two options for this model:
1. You can order our exclusive modified control unit (part # CU150) with our proprietary upgrades for $95, or add $15 for a new select button assembly making it part # CU150B for a total of $110.
Then if you return your defective control unit in repairable, good cosmetic condition, we'll give you a core refund of $30.
It comes with a one-year guarantee. For details, see: http://www.microwavedisplay.com/exchange.htm
2. We can repair your existing control unit for $39.95 in about a week or so with a one year guarantee.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller, AS-EET
[email protected]
Sharp Carousel Microwave has no power
I too believe that a "protection fuse" was possibly blown. It would need to be found and get replaced. Hopefully it is just a fuse and nothing else because the way it sounds to me, the microwave may be damaged.
Good Luck!
1helpful
I have a Sharp Carousel microwave model R438DV 1200 watts. There is a small 5x7 screen on the right side wall. It now has a small hole and has char marks on it. When I use the unit a fire starts o
You have to replace that small screen which is called wave guide. If there is a sharp authorised service centre near to your place you can buy the part from them. Do not work the oven without replacing that part.
Microwave Key Pad stopped working
buy a new one they are not expensive wal-mart has 1000w for about 80 bucks
14helpful
6answers
Sharp carousel R1754 microwave...display screen keeps scrambling
Stay away from Microwavedisplay.com and William E Miller. He will take your money and will not return your display unit let alone repairing it. Do your research. There are a lot of us out there!!!
1helpful
Sharp Carousel Microwave Convection Oven
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Then let us know if the hard reset does not fix it.
You may have a bad keypad.
Top Sharp Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
