Hi dennis Temple, I want to help you with your question, but I need more information from you. Please Call Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7Hi dennis Temple, I want to help you with your question, but I need more information from you. Please Call Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7
You can't post conmments that contain an email address.
Xerox online help is not particularly helpful! Google is often a better solution, but in your case, you need a service call. One of those new boards may be faulty.
This code means that printer is not detecting the cartridge. you can try to to remove it and re seat it or it could be faulty, her is a list of all of the codes. http://www.metrouk.co.uk/pdf/xeroxdc12faultcodes.pdf
The problem is the ibt belt sensor is not reading the silver patches on the edge of the ibt belt. They are either scratched or the sensor is dirty or faulty. Replace patches and clean or replace ibt belt sensor
91.858.00 is reservoir thermistor open circuit,
cause can be faulty/disconnected printhead cable
or faulty printhead. Unfortunately, there is not a lot
you can do.
Try a second reboot, if that fails return to shop for new
or contact Xerox for a DOA swap out.
Hope this helps.
if its a u9-1 code it is the lamp that is faulty. Sometimes it can be the connections either end of the lamp but normally the lamp itself. It will probably cost as much to fix as it would to get a new one to be honest
