Can't open door of Panasonic microwave model NN-2959
It sounds like the push to open lever is cracked or broken. You have to remove the 'wrapper' to open the door manually from the inside to check the 'door keys' or door hooks to make sure that they are in tact. Then, check the door opening lever between the 'push to open button' and the lower door key.
Testimonial: "Thank you for replying! You really seem to know what you are talking about!"
SOURCE: Panasonic microwave model NN-2959: can't open door.
Hi! if the parts is to much expensive i think it is not worth it. considering the years it has serve you.
Testimonial: "I thank you for caring about my problem and taking the time to respond! You are right. 14 years is respectable and I could consider buying a new one."
