Dixon is a trade name and not the manufacturer.
Service manuals are available for manufacturers equipment. Find out what make it is and then you may find one but as they are budget items, I wouldn't expect one to be available.
Try google etc.
Dixon were mostly known for making knockoff copies of more expensive name-brand models. So which one does this Dixon look like? Or, what's the Dixon model number?
Have a look on Google at 'bass guitar' and see if you can find the lookalike. Then we may be able to suggest a value, but it won't be over US$300.
www.dixon-ztr.com/ddoc/DIXO/...USen/DIXO1994_USen_5421_.pdf The information in this operator's manual applies to all Dixon ZTR Model 5421 Mowers. .... Before backing your Dixon Mower; stop, turn around and look. 13. ... startsvibrating, and any damage should be repaired before restarting and ... 13 GA stamped steel construction, 3 blades, 42" cut width, cut height approximately.
sounds like a fuel problem or its getting too hot, check your fuel filter for flow, then look to see if there is any thing blocking the air flow through the cylinder, clean and remove blockage, if problem persists after cleaning, replace carburetor.
