Question about Compaq Presario 4410US (470027-053) PC Desktop
Compaq Presario 4410US Memory Upgrade Problem
I have an old Presario (pre-2001) that has 384KB of SDRAM (2 slots, 256K in one, 128K in the other). According to various memory suppliers on the web, the system should support a max of 512KB, so I bought a 256KB SIMM (PC-100/133) and installed it in place of the 128KB SIMM. Upon powering up the PC, the screen says that I have more memory than the system can support. I have also upgraded the BIOS to the latest version available and still no luck. Any thoughts?
  • ikkenom May 11, 2010
    What happens when *ONLY* the new stick of RAM is installed? How much RAM is reported? What happens when *NONE* of your sticks of RAM are installed? (Some motherboards have their own RAM, and will function without any "extra" RAM.)
    President:
  • 1,015 Answers
Is it the motherboard telling you this or the operating system? Are you running windows 98 or windows 200? If the operating system is telling you this and you are running windows 98 then that could be the reason. Windows 98 seemed to have problems running 512mb of memory. Also make sure memory latency and voltage are correct ion the BIOS. The older motherboards could not always auto detect memory and you may need to adjust the memory settings in the BIOS. Try running the computer with just the new stick of memory installed...just to make sure memory works and is good.
Posted on Sep 10, 2009
  • Compaq Master
  • 4,806 Answers
In some instances your PC may not be properly recognizing one or more memory modules. Because you've recently installed new memory, check to be sure it's properly seated in its socket and the module is compatible with your system.
If the module is properly secured and appears to be compatible with your system, remove the RAM and try cleaning the pins using rubbing alcohol and a cotton swab. Clean each socket on the motherboard, as well with a soft, clean, dry paintbrush and then blow the remaining dust out.
If problems persist, try changing the order of your memory modules. DIMM sockets on the motherboard are labeled (DIMM0, DIMM1, etc). You should always start installing memory in the lowest numbered socket available. In many cases, the BIOS will probe the memory module in DIMM0 and address all memory according to the specifications of the module in DIMM0. If you've installed faster memory in DIMM0, the system may not be able to communicate with slower modules in other slots. Placing a slower module in DIMM0 may fix your problems; however, the faster modules will then, of course, run at a slower speed).
Hope this helps.
SOURCE:
RAM capacity ?
Memory Upgrade Specs for HewlettPackard Compaq Presario SR1215CL Computer. The HewlettPackard Compaq Presario SR1215CL Computer takes the PC3200 DDR SDRAM 184-pin DIMM Memory Type, and comes installed with 512MB (Removable) of Memory. You can upgrade your HewlettPackard Compaq Presario SR1215CL Computer to up to a maximum memory capacity of 2 GB Memory, the system has 2 Sockets to install Memory, already with 512MB (Removable) standard Memory installed. For best Compaq Presario SR1215CL Computer performance use the maximum amount of allowed Memory per slot for your Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible http://www.memorystock.com/memory/HewlettPackardCompaqPresarioSR1215CL.html
Apr 20, 2013 | HP Compaq Presario SR1215CL (82916052980)...
IBM T23 wont turn on after adding new RAM
Hi - according to memory suppliers your T23 has the following memory capacity / requirements:
  • IBM ThinkPad T23 maximum RAM capacity: 1GB
  • Your IBM has Two (2) memory slots or sockets
  • Module upgrade PIN count is: 144-PIN
  • The memory speed is: SDRAM 133MHz, PC133
  • The laptop DIMM type for the ThinkPad T23 is: SODIMM, SO-DIMM, Small Outline DIMM
  • Non ECC
If you are meeting these requirements, you may have a defective module.
Also, according to Lenovo's page on the machine:
Memory
The system has 128MB or 256MB of memory standard and can be configured for up to 1GB of addressable memory. Memory options up to 512MB SDRAM SO DIMMs each can be added in the two available slots for memory expansion. The standard 128MB of memory is expandable up to 640MB and the 256MB of memory is expandable up to 768 MB of addressable memory with 64, 128, 256, or 512MB SO DIMMs without removing the 128MB SO DIMM that is standard in one of the internal slots for memory. For customers that need the maximum 1GB to which memory can be expanded, it is necessary to replace the 128MB or 256MB card with a 512MB card plus add another 512MB card in the extra slot. Only 133MHz DIMM memory can be used in this system. The use of 100MHz DIMM memory is not supported in the T23 systems.
This means yo can trouble shoot the 512MB modules individually by installing one of the original 128MB modules and one of the new 512MB modules (for a total system memory of 640MB). If it does not boot, try again with the other 512MB module. This will help you identify a defective module that may be preventing the machine from booting.
I hope this helps & good luck!
Sep 28, 2012 | IBM ThinkPad T23 Notebook
I need to know what RAM I should use in my Compaq Presario 5000 desktop computer
You have three Ram Memory slots.
EACH ram memory slot's maximum amount is 256MB
Total Maximum Amount for the computer is 768MB.
Uses SDR Sdram ram memory.
[Single Data Rate Sdram. Commonly just referred to as Sdram.
That is a misnomer.
All ram memory from SDR to DDR3 IS Sdram.
Synchronous Dynamic Random Access Memory.
SDR Sdram = Single Data Rate Sdram
DDR Sdram = Double Data Rate Sdram
DDR2 Sdram = Double Data Rate 2 Sdram
DDR3 Sdram = Double Data Rate 3 Sdram
Just thought i would share ]
Uses SDR Sdram that operates at a frequency rate of 133MegaHertz. (133MHz)
Also known as PC133.
Make sure it is,
A) Non-Buffered
B) Non-ECC
C) Low density
D) CAS Latency of 3 (CL3)
E) Uses 3.3 Volts
Here's an example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=423457&CatId=828
One more,
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146303
For questions post in a Comment.
Regards,
joecoolvette
Dec 08, 2010 | Compaq Presario 5000 PC Desktop
How much can you upgrade memory (RAM) in a asus p4vp-mx motherboard. There are 2 slots with 256K each (128 pin, I think)
The Asus P4VP_MX has two slots for DDR2 SDRAM and supports a maximum 2G of memory, 1G per slot.
Aug 06, 2010 | ASUS P4VP-MX Motherboard
I have a compaq Presario SR5050NX and wish to max RAM
Yes, you can only upgrade to the 2GB limit using DDR2 SDRAM
Here is a link for you.
Hope this helps.
http://reviews.cnet.com/desktops/hp-compaq-presario-sr5050nx/4507-3118_7-32399105.html
Nov 03, 2009 | Computers & Internet
RAM increment
yes just pur chase 1 128 MB or 512 MB or 256 MB ram but check first *********** bord ram module
check your old 64 Mb ram if it has 1 notch it is ddr1 or ddr2 if it has 2 notch it iks sdram
then pur chase from shop.
then fix it on secodn slot
Apr 24, 2009 | Compaq Presario 5000 PC Desktop
Want to replace 2x 256mb of memory with 2x 512mb of memory into my hp compaq presario v4000
Hi there.
Yes you can upgrade the memory to 2 x 512MB DDR SDRAM memory.
You will be pleased to know that the system supports up to 2GB DDR SDRAM memory (2 x 1GB)
Please be gentle when installing the new memory taking care to remove the battery and the mains power from the laptop first before installing.
Have fun and thanks for using FixYa!!
Mar 24, 2009 | HP Compaq Presario v4000 Notebook
Memory upgrade
First step : Make sure the memory you purchased meets the following specifications
"168pin PC133 SDRAM DIMM" which should be easily accessible from wherever you bought it.
If not, then you can find memory here. that the company guarentee's will work with your system. Also - You want to make sure the memory that was in your system to begin with is identical to the memory you are sticking in it to get it to 512MB Systems that are this old with "PC133 SDRAM" are very picky about what kind of ram you stick in them. Make sure wherever you purchase your memory from, has a guarentee that it will work in the make/model of your computer.
Mar 14, 2009 | Compaq Presario 5000 PC Desktop
Memory problem
you may have purchased a memory stick that requires more speed than your memory block can give. the speed for this lap top should be around 455-500 MHz on the memory block. if the memory stick requires more than that, its not going to work.
Mar 11, 2009 | Gateway M305CRV Notebook
RAM upgrade presario 7594
How many memory did you install ? You should insert the memory to the primary slot. You shoould remove the old one and replace it by a new one.
May this site will help you: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph03886&lc=en&cc=us&dlc=en&product=94524&lang=en#N822
thank you . Please leave comment b4 u rate, thanks, melnavz
Jan 30, 2008 | Compaq Presario 7594 PC Desktop
Compaq Presario 4410US (470027-053) PC Desktop Logo
63 people viewed this question
Top Compaq Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
