Tractor ran out of gas, put more in, now won't start again
The engine cranks, but doesn't start. Gets weaker the more I try to start it. is 5+ years old, ran fine up til now. Got through 1 whole yard and only the front of another when this happened.
Re: tractor ran out of gas, put more in, now won't start...
Battery may be weak, must have fully charged battery to sustain operational working condition, or alternatoor may be out, anyway check electrical system
This is not unusual on a diesel. What happens is there is air in the system. If this vehicle has an electric fuel pump loosen line where fuel enters injection pump then turn ignition key to the on position and watch for fuel to appear and then quickly tighten line before turning off key. Then try to start. If does not have electric fuel pump will need a second person. One will loosen line and watch while other cranks vehicle until you get fuel and tighten line before the other person releases ignition switch unless vehicle starts first. If that doesn't do the job do this where line hooks onto each injector. Probably will not have to do this to all injectors but could run rough until all the air gets out of everything. I have farmed with diesel tractor for 25 years and dad I drove the gm vehicles with the 5.7. You normally don't start a diesel without bleeding the air out of the lines although some will self bleed most won't. Hope this does the trick.
Most Fords have a fuel reset button. When you ran out of gas you tripped the circuit. Most of the time the button will be on the passenger side by the kick panel. The exact location should be in your owners manual or your local library or auto parts store will have a copy of one for your specific vehicle.
check spark plug sounds it s heating up to much make sure of oil level and if it has been sitting a while dump the gas in it and fill it with new and buy some sea foam and add a little to the gas
It depends on how far you ran it out of fuel. If you ran it until it would not run any more and then tried to start it again several times; you may need to bleed and prime the fuel system to get it started. You start at the line coming from the tank and move toward the fuel injectors. You have to loosen a fitting and have someone pump fuel until the air bubbles stop and then tighten. A friend once worked for two hours to get his tractor started after his daughter ran it out of fuel. This is why they recommend that you do not run a fuel injected car out of fuel and if you do to turn it off as soon as it starts to miss badly.
It is time to rebuild your carburetor paying special attention to the float and seat.
Gasket set is about $30 delivered and gallon can of gunk carb cleaner with a parts basket is $21 at kragen auto parts. takes about two to three hours. Or you can but a new carb for about $150.
First of all, you should never touch the gas when starting it, on a fuel injected engine. Whether engine is cold, or warmed up, you shouldn't touch gas pedal. That was o.k. years back when carburetors were used, but not with fuel injection. Yes you will cause flooding especially when warmed up. Now there is a good chance you have a sensor or something acting up, but I'm guessing they checked for that when checking battery problem. You may be able to check for codes by cycling key, have yoou tried that, or had codes read yet?
