SOURCE: Freezer left open and now won't work
Try to unplug the unit from the wall and let it sit for a few minutes then plug back in. May reset the door alarm lock out. Also, moisture in the air can be drawn in and freeze up the whole thing. That means turning it off with doors open for about 36 hours... Moisture is a killer in a freezer, freezes and blocks up every air circulation vent, etc.
SOURCE: Viking freezer frost build-up
Sounds like a defrost problem. Check to see if
there is any frost buildup in the back wall of the freezer. If so, it is not
defrosting as it should.
If you don’t know what these are then unplug the machine and let the ice
melt in the freezer overnight with the door open. Then try it the next day, if
is cooling fine then you need to have a service person replace one of the above
items.
Mike
SOURCE: Left the door open on my Freezer last night and now it doesnt wor
After looking at some advice from others I turned the internal dial to the OFF position, then turned it back to 6 or 7, and left it for 20 minutes, and it is now freezing again.
SOURCE: Left door open on freezer last night and now it wont work
turn it off for a day or two let it defrost and then turn it on. it just has frozen up the coil, or the compressor has heated up cause it was working to hard turn it of for a cople of hours to let the compressor cool
SOURCE: freezer door won't open
k i would take say somthing hot or warm that you can melt the ice with (hot water in a contaner) and drag it aacross the ice
