It worked fine for months and now it just wont turn on. This happened about a week ago and now my father who bought his at the same exact time wont turn on either. Any ideas what this could be?
Make sure green light is on if using the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..
if you tried charging it with both house charger and car charger and tried to start it like i explain and it still will not start, its most likely a bad power port which is very common with this model and many other magellan models.
bill
SOURCE: Magellan Roadmate 800 freezes
i have a 800 also but it does not freeze because i make sure it is up to date on all firmware and software,if i was you chk out for updates on the magellan website after you register your unit then if ther is, which i know do the update and you will have no problems after that.let me know how it goes.
SOURCE: magellan roadmate 1200 will not turn on
plug it in to either the home charger or the car charger for a few minutes,(is the green light on, on the car charger) then press the power button for up to 15 seconds.if that fails, try a hard reset. little pin hole on the side(use a paper clip) if that fails you might have a bad usb connector.
SOURCE: I need driver for magellan roadmate 1200...thk
there is no specific driver for your gps. you need to hook it up to a computer running windows XP sp2 or greater for the computer to recognize and install it.
if your getting an error when you hook it up, let me know and can try something else
bill
ALL That is necessary for
the Triumph Of evil is
That good men do
nothing.
Testimonial: "yesss"
SOURCE: Need an update for magellan roadmate 1200
Magellan® RoadMate® 1200 Software Update Version 1.50/3.12 - Release
Notes
This update applies to Magellan RoadMate 1200. It includes the
following features, fixes, and improvements:
Improvements:
The software update version corresponds to your current software
version:
You can locate your software version by following these steps:
Download Update: (Click here:)
I WANT TO DOWNLOAD THIS UPDATE
