I can sign on and use verizon as long as I do not use my vpn. When I use the vpn I get disconnected from verizon within minutes
This is a common problem with VPN and by no means confined to Verizon. You will need to check with whoever you are VPN connecting to as it is most likely they that are experiencing a problem and dropping your connection. Contact the host Network Admin or Support team to assist you. I have had this happen many times, especially when travelling and it has never been an issue with my laptop and has always been the host.
You need to speak with a service rep at Verizon. I dont know why they wold not allow you to use your network.
I had the same problem with my VPN dropping the connection after a few minutes. I tried a lot of things. What worked for me was realizing that OpenVPN is a part of most VPN software.
OpenVPN requires that the VPN user to have administrative privileges https://doc.pfsense.org/index.php/Window...
Windows 10 does not run in administrative mode automatically without specifically telling it "run as administrator". Not all programs used in Windows 10 need administrative rights to run properly. However, OpenVPN in Windows 10 does need administrative privileges to run properly.
To assign your VPN program administrative privileges in Windows 10, "right-click" on the VPN icon on your icon page. Then click on "properties". Then click on the "advanced" tab. Afterward, check the box that says "run as administrator". Next click "apply". Last, click "ok". That should do it.
You may have to assign yourself administrative privileges before doing the above (click "windows" key and "x" key at the same time, then click "run as administrator"), if the "run as administrator" box does not appear in the "properties"-"advanced" tab.
If you want to run your VPN as a non-administrator, you can http://www.hacker10.com/computer-securit...
Apparently, OpenVPN routes traffic while you are using your VPN. If OpenVPN cannot route the traffic, it is an error. If an error occurs, the VPN connection can drop out.
Again, OpenVPN is a part of most VPN software so run your VPN with administrative privileges or non-administrative privileges and be "happy" again!
