Coffee Makers & Espresso Machines Logo
Posted on Sep 10, 2009
Need spare parts for breville cafe roma - Breville Coffee Makers & Espresso Machines
  • Anonymous May 11, 2010
    Which part are you looking for? You can find replacement filter rings athttp://www.vancouverwireedm.com/caferoma... .
Ryan
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 07, 2015
Ryan
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4028
Points
11
Sure, go to amazon and take a look, here: Amazon com breville cafe roma parts.
Regards
Ryan
Anonymous
Level 1:
New Friend:
  • Posted on Oct 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4028
Points
Here's a link. I have the same unit. This is the Breville Cafe Roma ESP8XL, same as the Mr. Coffee. http://www.thegourmetdepotco.com/store/store_details.asp?item=4442
2 Related Answers
Anonymous
  • 4 Answers
  • Posted on Dec 09, 2011
SOURCE: Where can I find (and purchase) the "single wall" filter (single shot) for the Breville Cafe Roma
Hmm,Maybe you try here:http://www.busytrade.com/products-search/single-wall.htmlI hope this answer can help you.
Anonymous
  • 11 Answers
  • Posted on Aug 13, 2010
SOURCE: I have a Breville Cafe Roma Machine. I made about...
have you tried to use the sharp pin and try to dislodge coffee grind from the filter cup? You will need to remove it from the filter holder to gain access.
Free download manual for breville espresso machine
Please log on to the link below and click for support from your location.
http://www.breville.com/
Plastic baffle came out of drip tray when moving.
I think it should fit in the back of the driptray.
/Mirran
1helpful
Breville ESP8XL Cafe Roma does not pump, or build up enough pressure to push the water through the coffee. Help.
Make sure the filter is clean, that in the holder and in the machine. If it is clean then i think your pump have to be replaced:-(
9helpful
3answers
Breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
We had that happen and it was a crack in the black ring that holds the filter. Breville could not supply us with one but we found an OEM part in aluminum from http://www.vancouverwireedm.com/caferomadiyt.htm. We received it 1 week after ordering. It was pretty easy to replace. Our machine works fine now.
Breville cafe roma
Obviously the problem is with your grind, not the Breville. SImply adjust your grind to finer.
Top Breville Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Sulejman Sulejmani
Sulejman Sulejmani
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
