We need the brand and the model
but for starters, please check on the links below.
http://forum.appliancepartspros.com/washer-repair/4501-washer-makes-extremely-loud-noise-during-spin.html
http://www.thestuccocompany.com/maintenance/Washing-Machine-noise-during-spin-cycle-169980-.htm
http://www.askmehelpdesk.com/appliances/washing-machine-noise-during-spin-cycle-167960.html
SOURCE: kenmore front load washer #44072 drum banging noise
I have the same problem...the solution is called new washer. I was told it could be overhauled to the tune about $600...barrings are going out. Mine is just 7 years old and that's disappointing.
SOURCE: Kenmore 80 series 110 washer making loud noise during final spin
Make sure all springs are still in their place tilt the machine back and look under it and you can see them. 2nd all legs must be level as well as the floor.
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
SOURCE: Washer Clicking/Ticking Noise
Washer is four years old. It makes a loud noise when agitating and now the drum is jammed. What can I do to fix it?
Thanks,
SOURCE: kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete
and leveled to perfection, the force of a heavy wash load spinning in
excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the
shocks that are used to dampen the spin cycle might have been broken or
damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
When
my washer did that, I found that the shocks that hold the tub were
bad...
Check out this tip I wrote about the noise and
vibration that front load washers can make..
Washer Problems
Washer
noise
when spinning
heatman101
