Question about Sony Televison & Video
My 2003 Sony KP-57WV600 decided to black out. Sound if there, but no picture. The three lense lights come on when power is applied and go out very quickly. What could be the cause?
SOURCE:
  • 184 Answers
SOURCE: I have a Sony KP-57WV600 projec. have picture for
You have a shorted blue CRT (picture tube)
The problem is that these TVs are known to have defective CRTs but Sony can no longer supply them. There is a company in Texas that rebuilds them, but its an expensive repair.
Its a shame that Sony has not been forced to take care of their customers. I've replaced hundreds of these CRTs and seen hundreds more after the supply ran out.
Sony knew about this issue way back in 2002 but only resolved complaints for a limited time and did nothing to notify owners whom they could easily indentify by serial number.
Let's hope we don't give up our auto industry or we'll soon see the same behavior there.
michtech
Posted on Feb 19, 2009
SOURCE: Blue to Black screen on Sony KP-57WV600
Rowdyroddy,
Thanks you so much for this info.
I had the same problem with my Sony KW-57wv600. Blue screen turns black after a few seconds, and then standby light flashes seven times.
I called a local TV technician, and described problem. I was told it would not be cost effective to fix. After reviewing the "simple" instructions given on www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html I figured I had nothing to lose.
10 minutes to remove front panel, a "very slight" turn of a screw, and TV worked again perfectly. I could not believe it!
Thank you so much for your help!
SHAME ON SONY FOR NOT POSTING THIS FIX ON THEIR WEBSITE! SHAME ON THE TECHNICIAN AT SONY WHICH INSISTED A SERVICE TECHNICIAN WAS REQUIRED.
I have always been a fan of Sony, swearing by Sony products exclusively. After this experience, I am now forced to consider some other options when purchasing electronics in the future.
Posted on Mar 04, 2009
  • 13 Answers
SOURCE: Sony wide screen projection tv model kp-57wv600.
I found this solution from SONY's website.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
I hope this helps.
Posted on Aug 05, 2009
SOURCE: I have a sony tv model# kp-57wv600 serial #
When turned on the visual is blurry. the image color is only red. And when i adjust the color it doesn't work.
Posted on Nov 27, 2010
SOURCE: sony kp-57wv600 tv turns on
KP57WV600...
1. remove 5 screws from behind each speaker
2. grasp center panel at the bottom and "pop" forward. Swing upward, set front panel aside.
3. Remove center wooden panel.
4. Look for "black box" with six screws at the front of set. There is torque paint on screws.
5. (my set would go green before going black) I turned the center bottom screw (green) appx. 1/8 to 1/4 turn counter clockwise.
Plugged in the TV and it works great now!
Happy TV Viewing!!!!
Posted on Dec 27, 2011
Sony Projection TV problem
sony rear projection KP series are know for having bad utbes after while..ihad seen the blue tube goes on most.
Jan 22, 2010 | Sony KP-57WV600 57" Rear Projection...
Sony wide screen projection tv model kp-57wv600 problem. Sound with no picture. Stanby red light blinks seven times? What parts do I need to repair the problem. Thanks ,Gary
I hope this helps.
Jul 19, 2009 | Sony KP-57WV600 57" Rear Projection...
No picture or sound
You need a professional.
Stop using the TV until it is repaired.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Sony KP-57WV600 57" Rear Projection...
I have a sony KP-57WV600 Big Screen Rear projection television. The problem is this: When I first turn the tv on the picture is fine, than after it warms up- the screen turns red. What would the problem...
Let me know when TV warms up does it go to standby?
If yes, standby light would be blinking, let me know how many times it blinks?
And if TV does not go to standby mode, does picture remain with red tone?
Dec 06, 2008 | Sony KP-57WV600 57" Rear Projection...
Cleaning the screen cover on my sony big screen
To clean its front screen, you should not open front cover as its complicated procedure. just take off its back cover as its shown in picture and use air-blower to clean dust. Then use soft cotton cloth to clean its screen from internal and 3 bulbs / lenses (CRTs) and job is done.
Need further help, let me know.
Bye.
Sep 13, 2008 | Sony KP-57WV600 57" Rear Projection...
Sony KP 57WV600
how many times does it blink?
Mar 26, 2008 | Sony KP-57WV600 57" Rear Projection...
i too have 57wv600 and your problem is same as mine VOLTAGE withen tube is off ...this is common problem sony knows full well and will not tell us this voltage can be adjusted with a philips screwdriver i had blue lines then solid blue then shut off...7 blinking lights ...went to this site followed directions (too simple)and now i have perfect picture.serviceman said i needed new tube.b.s. ...so never change your tube it is not the prob!!!!!!!....go to www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html read post(comment) near bottom of page by paul t dated 12/26/2007 and instructions on how to remove our front panel is fully explained ...a screwdriver will fix your problem I guarantee it.....
Dec 28, 2007 | Sony KP-57WV600 57" Rear Projection...
No picture or sound - Error code with Six blinks
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206
Sep 24, 2006 | Sony KP-57WV600 57" Rear Projection...
Televison & Video Logo
44 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
