Question about Orbit Hardware & Accessories
Orbit timer problem. I have 4 stations . once all stations watering is done , the unit turns on again to station one and goes thru all four cicles. How can I make it stop watering twice.
SOURCE:
mydogisk
  • 50 Answers
SOURCE: Solenoid on one station, sprinklers on another, cant turn both on
the should be a pump or master solenoid connection inside the controller
Posted on Apr 13, 2009
damneddle
  • 1607 Answers
SOURCE: where can i go to
Hi there!
You can find the manual in this link:
http://www.hardwarestore.com/media/pdf-misc/607980.pdf
It is in PDF format so you need an acrobat reader to open it. If you don't have one yet you can download and install it for fre here:
http://get.adobe.com/reader/
Thanks for using fixya!
Posted on Jun 01, 2011
SOURCE: How do I get a
Welcome To FixYa
I was able to locate a manual for your timer. Go to this website
http://www.orbitonline.com/lib/media/57894-24%20rA%2812%291.pdf
Please note that this is in PDF format which means that your computer needs to have adobe reader installed. If you dont have that you can download it here
If you have further questions just reply back and I will be happy to assist you
Hope this Helps
Posted on Jun 04, 2011
SOURCE: i ned to reset the
To reset your timer, you'll need to replace the 3 AA batteries then press the reset button on the back of the housing.
If you'd like to refer to the manual, you can find the manual at orbitonline.com. Just click on the "manual and guides" link under the "Support" heading found on the left hand side of the home page. Enter the model number of your timer "62015" and click the quick search button. Your search will provide a link to the manual in up to 5 different languages in a pdf. file format. Click on the manual of your choice. Once the manual is downloaded (this will take a second or two if you have high speed) onto your computer you can print out the manual for future reference.
Hope this helps.
Posted on Jun 05, 2011
aquaman987
  • 927 Answers
SOURCE: I just got an Orbit
You don't program each station. You only program one start time that begins the cycle that consists of the three stations.
Remove all start times but the first one and make that 5:45.
Set the station times to whatever you want, 12 minutes.
At 5:45, station 1 starts.
at 5:57, station 1 shuts off, station 2 starts.
at 6:09, station 2 shuts and station 3 starts.
at 6:21, station 3 shuts.
Your FixYa Texpert,
Gary
Posted on Aug 26, 2011
Testimonial: "Thanks Gary , you are a lifesaver, the instruction I got has no info about it, only unimportant stuff. U R amazing your instruction simple and great"
How do I program model # 57114 from station a to b to c
The model of Orbit sprinkler timer you show has 4 or 6 zones for watering. I provide link below for instructions for use. Reading it, I don't think this timer has A, B, C, schedules if that's what you mean (whole different settings on each). Other timers commonly do however that feature in my experience is rarely used. If you don't like this timer, Home Depot has a $20 timer 4 station that I've found is easier to understand than many of them, also a 6 station for a little more same type (think is Orbit not sure). May need to zoom instruction shown from the link.
Jul 09, 2016 | Hardware & Accessories
Getting sprinklers to come on
Is it a one way valve? If so you may need to turn it around, if it was just installed from new... make sure that the dust caps are not inside the valve and obstructing the line
Jun 02, 2016 | Orbit Hardware & Accessories
I have a 6 station orbit timer and I have problem with station 2 odd days coming on again after station 4 odd days the time is set to come on at 6 am and run for 60 min an10 min after it shuts off to start...
I am somewhat confused about your station numbers. How many stations do you have? What is Ihappening with stations 1, 3, 5, 6?
Regardless, this is probably what is happening.
No matter how many stations you have, YOU ONLY PUT IN ONE START TIME. That one start time begins the cycle that starts with station 1 and proceeds to the other stations based on your station RUN times.
If you have one start time of 6:00 am, and a run time of 60 minutes for each zone, then
At 6:00 am station 1 starts.
at 7:00, station 1 shuts off & station 2 starts.
at 8:00, station 2 shuts and station 3 starts, etc.
You are not programming the individual start times for each station.
If you put in more than one start time, the timer remembers and will run all stations then go back and begin again and if there is a third start time, it will begin a third time.
Gary
Sep 02, 2011 | Orbit 57882 9 Station Super Dial...
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/support/
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
Can i get online instructions on how to program my
moved into house with 4 station Orbit sprinkler unit. Manual is faded, cannot figure out how to get it to control the sprinkler system. Can I get online instructions on how to program it?
Jul 22, 2010 | MicroBoards Orbit (ORB-4201-01) Burner
How do I test a specific Orbit Watering station without turning on the whole system?
I have done this in a couple ways. With a digital timer you can select a zone on manual and turn only that zone on. with a mechanical timer, you can set the dial to that zone and increas the duration. You can "hot wire" the zone by moving the zone wire to connect to the low voltage wire input to the zone. You can take a transformer out to the ground box and with an extention cord "hot wire " the zone at the ground box.
May 06, 2010 | Orbit 57882 9 Station Super Dial...
Apr 12, 2009 | Orbit Hardware & Accessories
Hardware & Accessories Logo
Top Orbit Hardware & Accessories Experts
Craig Butler
Craig Butler
john h
Marvin
Marvin
Are you an Orbit Hardware and Accessory Expert? Answer questions, earn points and help others
