Question about Bunn Coffee Makers & Espresso Machines
Bunn smart wave APS 15 won't brew.
Tank fills, hot water faucet works, tries to brew,solenoid and air pump on top of the brewer work, no water comes out after about a minute I get error 5. What to do?
SOURCE:
Buffalo12980
  • 625 Answers
SOURCE: Coffee Brewer comes out warm not hot
look at the top of the coffee maker you'll see two screws and the warmer tray and the cover for adding water. remove the two screws and lift the top off. the warmer has two push on spade terminals. pull the wires off them. below is a tray where the water goes and you'll see a brass bushing. this is screwed into a fitting on the water tank. use a piece of steel as a spanner and unscrew this fitting. don't lose the gasket that's under it. the main wires for the burner element and thermostat are also under this tray. look at the top. there's nine screws that hold the top on the water tank. two white wires go to the tank warmer and two wires go to the tank heater inside. you can try turning up the thermostat setting to a higher range and see what happens. there's a copper pipe that comes from the tank to the sprayhead the tank holds approx three urn fulls of water. if you have an analog meter you can check the element for continuity on the RX1 range. Do the same with the tank warmer element. Bunn-o-matic has a web site you can buy replacement parts or nelson appliance can get you parts too.
Posted on Nov 19, 2007
Corey_allen8
  • 23 Answers
SOURCE: Inave a Bunn VLPF coffee brewer, water is leaking
THe most likely answer is that the tube that leads to the sprayhead is clogged with lime. You will need to remove the spray head wich is located above the brew basket and make sure the holes are not clogged with lime. Use a wire brush to clear them. In the field I would use a deliming spring but you may need to go to a lowes or home depot to find a tool you can use to clear the tube wich is what the spray head screws onto or just goole deliming spring and try to order one off line. It is a long flecible very tightly wound dpring about 14 inches in length or so. www.midstaebeverage.com
Posted on Nov 16, 2010
heatman101
  • 43501 Answers
SOURCE: won"t brew the coffe right and hot water coming
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 07, 2011
mc1bean
  • 3053 Answers
SOURCE: my bunn pour o matic coffee brewer will not brew.
Hello Doug,
This is a clogging issue. Meaning it needs to be cleaned. So what I want you to do, if first read this manual that I am sending you via a e-mail link. Just copy and paste link in browser; I am positive it is just clogged. In the manual it will show you some tips on how to unclog it with tooth pick etc... then you want to flush whole system with water and vinegar. Here is the link to put in browser. http://www.bunn.com/pdfs/commercial/manuals/10424.0000.pdf
Mike
Posted on Sep 30, 2011
  • 31 Answers
SOURCE: How much coffee per hour does the Bunn VPR-APS Pourover Airpot Coffee Brewer brew??
Bunn's pourover airpot coffee brewer brews 3.8 gallons of coffee per hour.
Posted on May 09, 2013
Hello. Bunn coffeemaker VPR Series. When water is poured in coffee starts to make. Carafe gets about 1/3 full and then just drips through filter for about 5 minutes. Never makes full pot.
VPS/VPR are pour over brewers. Like the 12 cup brewers you find at home, they need to be filled with 12 cups of water (a full pot), heated and then peculated over the coffee grounds and collected in a decanter.
BUT there is one main difference! The VPR and similar COMMERCIAL coffee machines are quick brewers. They usually have a pre-heated pot of water stored inside the machine.
* VPR's and similar machines REQUIRE a pre-fill and heating period prior to brewing. This means it's sitting on a level table and filled with water until water sprays from the brew head. At this point the unit is plugged in and the heater is turned on (there may be some water discharge from brew head as the water expands). Ready light will come on in about 15 mins.
* To Brew; Place coffee grounds in filter, place in funnel and brew head, clean empty decanter under funnel, slowly pour one full decanter of water (cold or hot) into brew tray. Do not overflow tray. Allow water level to sink before adding more water. Only fill with one pot as an equal amount will come out the brew head and funnel.
* Make sure the decanters are all the same size. do not mix a 12 cup pot with a 10 cup pot. One will over fill and the other will under fill. Make sure they match (in cup volume) FYI; Thermo Air pump pots are usually bigger than one pot. Typical filling only to 3/4th of the container. (I think most are in 2.5 to 3 liter sizes)
* If your not getting a full pot then the brewer was partially empty. The second brew (if done within the next hour) should come out full.
* If your still not getting a full pot then the water is leaking or is boiling off. Does it always steam from the top? Thermostat is shorted. Unplug the brewer and call vendor for service.
* Final; If your unplugging when not in use. Then follow the Pre-heat instructions mentioned above prior to plugging the brewer back in. If the tank has been emptied at night or dried up after an idle week. Then there is a chance you may over heat and blow the thermal fuse. Or at best have a half pot short brew as the water dried up.
* Note leaving the brewer plugged in without brewing daily is not a good idea. The water evaporates and eventually drys out the pot. Takes about 1-2 weeks but it does blow the fuse(s) and the unit will need service.
* Final; Follow the Bunn set up and care instructions (manuals from Bunn.com for down loading. *FREE*)
Aloha, ukeboy57
Jul 20, 2017 | Bunn Coffee Makers & Espresso Machines
My bunn will not pump any water into my pot the water is hot the plate is hot but want pump
* If this is a pour over (VPR, VPS, etc.) then you must pre fill it then pour in one pot of water to get one pot of brewing hot water out of it.
* If this has an external tank of water then it must be filled and make sure the float sensor works and pops up to indicate a filled tank.
* But most likely this is a CWTF, CW, or larger commercial brewer that has a plumbed in water line. If this is the case then the tank must be pre-filled and heater turned on. usually done by the vendor or installer. It should have been tested and brewed to check water level of brew. Follow the brewing instructions.
* Still not working? Call vendor for service. It could be timer, brew switch, water level board, water fill valve,brew valve. all need check and service to replace as needed. Many larger units have high voltages so call the tech to be safe.
Aloha, ukboy57
Jan 16, 2017 | Bunn Coffee Makers & Espresso Machines
Our bunn NHS Velocity was unplugged accidently. Now when we make coffee it is really luke warm and the light doesn't appear on
This is really a home style VPR brewer (but looks nicer)
if you listen to their video (link below) they mention it has a pre-heated tank of water already in the brewer. This means the brewer needs to be pre-filled with a full pot of water and pre-heated prior to using the brewer. Unplugging this unit won't be a problem UNLESS it was emptied of tank water and not refilled when powered up.
* The unit will try and heat up the tank of water but if empty then just air which overheats the unit then blows the thermal fuse. Call for service.
* The warmer is still working but it's not hot enough to brew frequently as the warmer may take up to an hour to get the tank hot enough to brew or it may not get hot at all if it's own thermal fuse blew too.
* Final; call for service to be safe.
Aloha, ukboy57
https://www.amazon.com/BUNN-Velocity-10-Cup-Coffee-Brewer/dp/B00EAQJCWW/ref=sr_1_1?ie=UTF8&qid=1516431654&sr=8-1&keywords=bunn+nhs+velocity
Dec 30, 2016 | Bunn Coffee Makers & Espresso Machines
Water overfill
The A10 has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
PS. Check your using the correct size decanter for this brewer. If it's a 10 cup brewer then make sure all the decanters in the office is also 10 cup. Pouring a 12 cup pot into brewer will have 12 cups of coffee come out (over flowing the 10 cup pot.) Note that not all decanters are made the same size. Other brands may be different. Test by filling a pot with water (from faucet) then pouring directly into pot in question. It should match and not under fill nor over fill.
Apr 04, 2014 | Bunn A10 Coffee Maker
Hot water faucet adjustment?
The Axiom uses a water level probe to keep the heater tank filled with water at a set level. The hot water facet takes water directly from the top of the tank. It's gravity fed with only the weight of the top portion of the water (the hottest area) to flow into the faucet. It is possible that your faucet 'Boot' or spring is bad and needs replacement. But it's designed to give you a single cup of hot water. Do not expect to fill a pot (or large french press) with this faucet.
* Call your vendor for service.
Aloha, ukeboy57
(the parts manual) https://catalog.bunn.com/public/docs/39131.0000/E17/01/000/39131.0000.pdf
Apr 03, 2014 | Bunn AXIOM AXIOM-DV-APS Coffee Maker
Leaking water
* Water leaking while the brewer just sits there? Leak in the tank. Call for service.
* water leaks only while pouring? Then your pouring to fast. Wait for the water to drop before pouring in more. If it still leaks even while pouring slowly then there is a leak in the fill tray. Call for service.
Aloha, ukboy57
Jan 12, 2014 | Bunn GRX-B
Bunn pour omatic commercial coffee maker will not brew and it leaks
VPR is a pour over "Volume Displacement" brewer. Required to completely fill the inner tank and heat prior to using brewer. BEFORE plugging in unit, water must be poured into upper tray and with brew funnel and empty pot in place. Keep pouring water into top fill tray until water drips out of brew funnel. Plug in VPR and allow it 15-20 mins to heat up. leave the pot as there may be additional water dripping. Remove power if there is any water spilling out from other places like the top pan cover or bottom of machine. With the initial heating done, take a full pot of water and slowly pour into the top filling tray. HOT steaming water should come out of the brew funnel to fill the (empty) pot. Prep is done and the machine can be used to brew a pot after 10-15mins of reheat time.
*** the machine you have needs to be checked for leaks in areas mentioned above. Water should only come out of brew funnel (if not present then the brew head or if that is missing then the brew pipe. All will need to be replaced prior to brewing.) Leaking under machine is an indication of leak(s) in pour tray,tank,tank cover, gasket, probe gasket. This machine like any used equipment should be checked out by qualified tech prior to use. Be aware that coffee vendors sometimes rent or loan brewers to customers.
Nov 08, 2017 | Bunn NHB Coffee Maker
Reservoir heats but won't dispense
If you are pouring water in the manual brew basin, then check the sprayhead holes, then the spray tube, those could be blocked. If using the auto brew, check the solenoid and or brew switch.
Apr 26, 2010 | Bunn 12 Cup Coffee Brewers with 3 Lower...
Coffee Makers & Espresso Machines Logo
32 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Inky Fingers
Inky Fingers
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
