When cycling see if ignitor glows if not replace if glows check gas valve
Check to be sure you have gas. I know this is a long shot, but one of my renters had complained about no hot water. When I went out to check, the pilot light was out and I couldn't light it. Then checked the gas stove and it didn't light as well. Then I check the gas meter outside the house and it was turned off and locked. Apparently they hadn't paid their gas bill.
SOURCE: Water is pouring steaming hot water from a copper
Sounds like the TP valve is releasing water.
http://waterheatertimer.org/Water-heater-leaking.html
To protect your property right now, turn off water heater:
Gas: turn gas valve to pilot so pilot light stays lit but burner will not turn on.
Electric: flip circuit breaker off
Next turn off water valve located on cold water line above water heater.
Last, open tub faucet to relieve pressure on tank.
Once pressure is off after a few moments, close tub valve.
The question is why is the TP valve releasing water.
1) Stuck TP valve: raise lever on TP valve and let back down slowly
2) bad TP valve: replace TP using same temp-pressure rating available from hardware store. Wrap teflon tape around threads and screw new TP valve clockwise until very tight. Make sure water is cool before removing valve from water heater. If you take out valve when water heater is hot, it will spew scalding water all over you. This is serious. Let the water cool down for several hours.
3) Runaway heating caused by bad thermostat
Gas: buy replacement valve at Lowes or plumbing store and replace according to instructions.
Electric: several causes. Test parts to determine which needs replacement.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
More support:
a) Fixya offers phone support where you speak with a fixya expert on telephone for a fee.
You can use this service if you hit a trouble spot when repairing your tank.
b) You can also call a plumber who will know exactly what to do.
c) You can post questions at a professional plumbing forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
PROBLEM #1 - HOT SURFACE IGNITOR DOES NOT GLOW RED
(Remember to wait for purge time, 17/34 seconds, on models so equipped).
Possible causes
A. No main power
B. Faulty transformer
C. Faulty thermostat
D. Faulty limit switch
E. Faulty blower interlock switch
F. Faulty hot surface ignitor
G. Faulty ignition control
Solution
Step #1
Perform normal system checks of main power, transformer, thermostat, limit
switch, blower interlock switch, and replace faulty component.
Step #2
With power on and thermostat set at its highest position, check voltage
between "TH" and "TR" on HS780 ignition control. If 24 volts is not present
check output at transformer. If no, replace transformer. If transformer
checks out OK look at other controls in the 24 volt circuit I.E.: thermostat,
limit switch, blower interlock switch. Check for 120 volts between "neut"
(L2) and "120" (L1). Check for 120 volts at the ignitor across "IGN" and
"IGN" terminals on the HS780 ignition module. If 120 volts is present,
replace ignitor. If no, replace the 780 series module
PROBLEM #2 - IGNITOR GLOWS RED BUT MAIN BURNER
WOULDN'T LIGHT
Possible causes
A. Improper ignitor alignment
B. Faulty ignition control
C. Faulty gas valve
D. High inlet gas pressure
E. Polarity reversed
F. No earth ground
Solution
Step #1
Check for availability of gas at gas valve. Make sure the manual valve
upstream of the gas valve and the gas valve are in the full on position. Also
make sure gas is being supplied to the system at the proper pressure, too
high will lock-up the valve.
Step #2
Check proper polarity of "NEUT" and "120" on the ignition control by reversing
the wires, if reversed gas valve will not open. If this does not solve the
problem, replace wires as they were.
Step #3
Check for proper ignitor position.
Step #4
Check for a good earth ground by using a meter connected between L1
and furnace chassis. Should read 120 volts, if no, check and/or repair ignition
ground wire or ignition control mounting screws.
CAUTION POLARITY MUST BE OBSERVED
Step #5
Check for 24 volts at the gas valve terminals; "1" and "2" on a 7200 series,
"M" and "C" on a 7100 series, "TH" and "TR" on a 7000 series. If yes,
check wire integrity or change the gas valve. If no, change the 780 series
ignition module.
That is pretty much all of the troubleshooting required.
Thanks for choosing FixYa,
Kelly
