Xerox Phaser  6110 Laser Printer Logo
Posted on Sep 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Deve home sensor error on samsung clx-3160fn printer
Deve home sensor error on display panel.
Anonymous
Level 2:
  • Expert 12 Answers
  • Posted on Jul 10, 2010
Anonymous
Expert
Level 2:
Answers
12
Questions
0
Helped
35891
Points
162
Dev. Home error can be fixed by stretching out a solenoid spring on the power cord side of the printer. The solenoid acts as a clutch to stop the spinning developer actuator at the right spot.
The problem is that the spring gets weak over time / the cogs round out over time and the solenoid finger is overcome by the spinning cogs, and resulting in selecting the wrong developer.
Open up the right side (power cord side) of the printer (take off top cover, then take off side cover). Then, find a solenoid (little metal square) that touches the white plastic vertical spur gear. Take the spring off the solenoid. Now, put the spring back on - only this time you will attach one anchor point to the middle of the spring as to pre-stretch the spring for more tension.
More pictures of the solenoid on Facebook:
http://www.facebook.com/#!/photo.php?pid=55779771&id=2257206&fbid=10100154259704133
  • 2 more comments
  • cemali0551 Sep 06, 2010
    many thanks, the problem is o.k
  • kerrytech Sep 08, 2010
    many thanks, I'd never have guessed what to do. changed a **** printer that failed after 300 pages to something usable. CLX-2160. remove small top back panel (2 screws at top) and 3 screws holding side panel. ease off panel. shorten spring by ~40% wind it once round the peg clockwise and under itself to stop it coming off.
  • Idlehands303 Mar 07, 2011
    For a year after we bought one of these, at the original retail price, it worked great. At just about a year, this sensor error popped up. We have had a really large scanner basically for a long time now. You must have posted this shortly after my last effort to get the thing working.
    For whatever reason, tonight I felt like checking the web for another answer and found this. Within 20 minutes, we had a working printer again! Thank you so much for posting this solution.
  • y123 Sep 16, 2011
    YES!!!!! This finally helped me to find the problem. I put the printer apart, got mad, did it over a few weeks later this summer, got mad again! This printer is so cheap, I keep reading about "young" printers already broken.
    Thank you so much for this beautiful flaw spotting. Just need to find the right new spring; mine is out.
Anonymous
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on May 17, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
7947
Points
35
Emtz the tank from the left of printer, wash him, drz and put on here place. if the problem persist change it.
HOME SENSOR EROR
Deve Home Sensor Error
There is a problem in the fuser unit.
Unplug the power cord and plug it back in. If the problem persists, Replace to the Main board.
2answers
Deve home sensor error on samsung clx 3175
Dear
There is a problem in the fusser unit.Turn the power switch off and on. If the problem persists, call for service engineer.
Thanks.
Non-working printer; no paper pickup
The solution shown for the Samsung CLX-3160FN All-In-One works also for the Samsung CLX-2160N.
The associated picture and methodology of "pre-stretching" the solenoid spring is virtually identical for both printers.
Worked for me on the CLX-2160N
See here
http://www.fixya.com/support/t4742967-deve_home_sensor_error
1helpful
I receive an error message DEVE Home Sensor error
the transfer belt is worn or covered in toner or has a label stuck on it or the sensor is dirty.
Problem for Samsung CLX-3160FN All-In-One Printer Deve home sensor erro
Please check the sensor of front door or back door, one of these are not working, chec softly by rolling your finger on it, and let me know if this works or not [email protected]
1helpful
You could try replacing the Image Unit (but these are quite expensive). This error actually refers to an optical sensor located in the gearbox (RHS of machine). The sensor controls the drive to the individual dev units, hence the "dev home error" if it malfunctions.
Probably a job for an engineer.....
4helpful
hi if u check the samsung manual herehttp://www.wisconsinimaging.com/downloads/clx3160manual.pdfthen u will find it in page 79 and it saysThere is a problemin the fuser unit.suggestion:Unplug the powercord and plug it backin. If the problempersists, please callfor service.
2helpful
Deve Home sensor Error as occur cannot get printer to work
The web does not offer alot on this error. However the users manual indicates it is a fuser issue. Try a new maintenance kit. That should include the fuser and all rollers.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
