I have a Strata CTX, DKT3010-SD. We purchased these telephones used. Could there be a code programed in phone that pevents us from dialing 911. When I dialed 911 the display said "conf" and a light lit up on a line where we do not have service and the line was silent. I looked in the manual (DKT3000/2000 series) I printed from the internet and tried the feature button "#911" and a recording told me "I am sorry the service you are requesting is not available on this line" It says the same message on all four of our phone lines. I did call phone company to check first and was told ALL phone lines automatically have 911 on them.
If I'm reading it right, it looks like when your dialing the 9 its accessing a pool group. Are you pressing the line button first then 911? Also did you try 9 then 911.
www.atsco.info/.../CTX%20DKT-IP%20Handset%20User%20Guide.pdf Hi please find above your user manual. Also often, well, sometimes, on the side/rear of the phone, there is a small slide switch, that is used to control the ringer, or as related hopefully the manual will show you how.
Depending on the type of Toshiba phone system, the programming steps may vary slightly but this should get you on the right track.
Changing the time on a Strata DK system must be done from the "main" or primary phone. It is usually extension # 10, or # 200.
1.-
With the phone on-hook, dial intercom, #, 652 (depending on the system type, the # may or may not apply)
2.-
Enter the correct time using HH/MM/SS, like 07:24:00
3.-
Press redial
Please follow the link below to download the complete manual for your Toshiba phone. It will answer your question, and you can print it for future reference.
speed dial must set at port ' 00 ' or 000 to check, use display phone, press #402 or #401 speed dial code are from 60 to 99 to set press speed dial , redial , speed dial code eg. 60, press 9 follow by destination number asn redial to confirm to use speed dial to call press speed dial short key follow by speed dial code or *60
what system u using?? if DK series go to phone port number "000" (at phone press Intercom #401 to check port), check at every phone with display phone. - to set speed dial press REDIAL SPEED DIAL standard speed dial code 60 or 600, follow by 9+destination number, REDIAL to confirm. - to call press speed dial + code or press * + speed dial code (*60 / *600) - if CTX/CIX must set at adminsrater phone. #66, speed dial code number (200-999), 9 follow destination number # - to dial press *200...
