Please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0000
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
You need to set you remote to work with the type and make of TV which you have. If you have your SKY box manual, it tells you step by step and also has the list and codes of each make of TV.
