First, check your USB printer connection to your Macbook from your Pixma MX310 printer.
If the USB cable is securely seated, make sure you have installed the updated drivers for your version of Mac OS X. Here is the Link:
Canon Pixma MX 310 Drivers for Mac OS X (v10.6/10.5 and earlier).
If you have already updated your printer drivers to the most current Canon Pixma update for your version of Mac OS X, then click on the Apple menu icon, located in the upper left corner of your screen and select System Preferences.
• From System Preferences, select Print & Fax.
• Within the Print tab, make sure you can see your Canon listed in that window.
If you can, proceed to perform a test print on any document you have on your desktop or folder of choice. If this does not help, from within the Print tab, select the Canon and press the "-" Minus button and remove that printer.
• Once it is removed, now click the "+" button
and re-add your printer.
• Once it has been added, attempt to test print again.
This should help get your printer back to printing again.
Regards,
-Mactechtrainer
