Without doing anything else, press the * button one or 2 times until what you want shows up on the display. Depending on the system, it toggles between extension, time and day, and date.
With the phone idle, you keep pressint the * (or the TRANSFER key) until what you want is on the display. It uses one or the other key because the 77xx phone works on more than one system.
While the hanset is on the cradle press # or * until the desired display is shown. If that does not work press the info key below that is shown on the screen.
Your extension reads 102 because that is the extension #.
Press either the tranfer key or the " * " star key and your display will change to time and date or just the date.
What happens if you dial 102? If it rings the receptionist, then you probably just have to reprogram the button. Without picking up the handset, press PROGRAM, the button marked 102, and dial 1 102 STORE then PROGRAM.
Now the button will dial 102.
If that doesn't work, check to see if 102 can be dialed from another phone. If they all go to 119, then someone set call forward at 102. It cancels with a 790 code on the intercom at 102.
If it is displaying "101:" that is your extension. You can press the * key (with phone on the hook) to scroll your display through date and time formats and to display your extension.
When it says "PITS-PGM NO" you will need to press one of the buttons on the numerical key pad to choose a function to change.
1) press "Program", then * *, then 1234, 2) press "0 0 0", 3) press "speaker" two times, 4) change the time 5) press "store". 6) pick up the receiver to complete the change.
Do this change on the "lead" phone and it will reset all the others on your system. Not exactly an intuitive process to be sure!
