Error f5 is due to a fault in the wash temperature sensor sometimes due to a breakdown or a bad connection. On some occasions the resistance may be damaged. Both the sensor and the resistance are in the wash tub.
Potential Causes
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
SOURCE: Kenmore Elite front loading washer HE 3t
"F05" is a water temperature sensor error. The following link explains:
http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
Make sure the connector is firmly attached to the NTC sensor upon your intial visual inspection. In many cases, the connector comes loose and causes the error. Make sure you follow the advice in the link provided for resistance readings. I hope you find this information helpful. Let me know if you still require assistance.
SOURCE: f5 code on a kenmore range
Hi mrscottd,
The f5 indicates a loss of the relay drive circuit. To correct you can turn the power off to the range at the breaker box and wait about 10 minutes, then turn back on. This will reset the board. If the error returns you will need to replace the electronic range control (ERC). The part number for the control is # 338692 price $338.49 at Sears or My price $299.99 delivered. Good luck to you and please dont forget to rate me.
Mike Anderson
Anderson Appliance
(865)945-3808
SOURCE: kenmore elite washer h3 has
The F5 error code indicates a water temperature problem. The control board circuit is not recognizing a resistance change in the water temperature sensor.
Richard
Roth
The
FixYa Team
You most likely have a loose connection at the tub sensor , or a bad heater.
Richard
Roth
The FixYa Team
