Found this online solution, hope this helps.
How to Replace a Husqvarna Zero-Turn Riding Mower Ground Drive Belt
https://www.youtube.com/watch?v=PS3c3o-fC4Y&app=desktop
SOURCE: I have a Husqvarna Pro Rider 15 ride on mower,cuutting deck broke
You may find this helpful. A complete manual you can download and use for this and other repairs.
http://www.gardenresources.co.uk/content/garden_machinery/manuals/husqom88hoen2003_1140142-26rideen.pdf
SOURCE: My Motion Drive Belt slipped
i had a 2148. you remove the mower deck as the first step. feed the belt over the pulley on top the transmission, then put it over the engine pulley. then have someone push the clutch pedal in so the tensioner pulley moves, put the belt in the guide pulley and on the tensioner. release the clutch put the deck back on and you are good to go. notice there are little keepers welded to the frame for the front, engine, pulley and it is easy to mistakenly put the belt over them instead of under them.
a general rule is that a pulley shaped like a Vee takes the V of the belt whilst a pulley which is flat takes the flat back of the belt. if you bear that in mind you will not have a problem putting belts back on. also there is a little decal on top the deck showing how the deck belt and deck drive belt go.
SOURCE: husqvarna riding lawn mower pto is not engaging?
when you dropped the deck did you knock off the pto electrical plug?
