1515n - I have the Magenta colour 'shadowing' the blue test. A mirror image of the blue text. [slightly staggered] Black is fine. Applies to all Word docs when printing in blue - can you help please? I only use genuine cartridges. Thanks Jules Radstock
This document provides information about replacing the print cartridge for the HP LaserJet 1010 printer series, including life expectancy and replacement instructions.
Print cartridge life expectancy
The life of the print cartridge depends on the amount of toner that your print jobs require. When printing text on letter/A4-size paper at five percent coverage, the print cartridge lasts an average of 2,000 pages. This assumes that you set the print density to three and disable EconoMode. (These are the default settings.) See Ordering supplies for information on ordering replacement print cartridges.
Changing the print cartridge
Follow the below instructions to change the print cartridge:
Open the print cartridge door, and remove the old print cartridge. See the recycling information inside the print cartridge box.
Figure 1: Removing old print cartridge
CAUTION:
To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper.
Remove the new print cartridge from the packaging, and gently shake it from side to side to distribute the toner evenly inside the cartridge.
Figure 2: Gently shaking new print cartridge
Pull the tab until all the tape is removed from the print cartridge. Put the tab in the print cartridge box to return for recycling.
Figure 3: Removing tape from print cartridge
Insert the print cartridge in the printer, making sure that the print cartridge is in position. Close the print cartridge door.
Figure 4: Inserting new print cartridge
I have same printer (Laserjet P2015D) with light print brand new and banding and shadows on solid areas. Tech support at HP has ruled out that the new cartridge needed breaking in (15-30 copies). They are now saying it could be a fuser issue and since the machine is brand new I should exchange it at the retail store. Disappointing because box stated it was mfg in Japan and I was expecting better.
Control panel
The printer control panel is comprised of six lights and two buttons. The lights produce patterns that
identify the printer status.
1 Jam light: Indicates that there is a jam in the printer.
2 Toner light: When the print cartridge is low, the Toner light illuminates. When the print cartridge is out of the printer,
the Toner light blinks.
3 Paper out light: Indicates that the printer is out of paper.
4 Attention light: Indicates that the print-cartridge door is open or other errors exist.
5 Ready light: Indicates that the printer is ready to print.
6 Go button and light: Initiates action or indicates status.
7 Cancel button: To cancel the print job that is currently printing, press the Cancel button.
