Hi Sue, try selecting with the Source or TV button on your remote control, if you can return to the DTV position
you must go through the different inputs and at some point the DTV option should appear
Indicate the model of the Samsung you are commenting on, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Sue, prueba seleccionar con el bot?n Source o TV, de tu control remoto, si puedes regresar a la posici?n de DTV
debes pasar por las distintas entradas y en alg?n momento deber? aparecer la opci?n DTV
Indica el modelo del Samsung que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
SOURCE: hitachi ultravision digital projection television
First try a hard reset to see if that will unlock it. Unplug the power cord for 1 hour; the power
SOURCE: Samsung TV remote control
I HAVE THE SOLUTION TO THIS PROBLEM.
Confirmed with Samsung tech support. Problem is with remote. to fix, simple take the batteries out of the remote. Press and hold the UP Volume button for 2 Mintues (no cheating, it has to be at least 2 minutes), this Reset's the Remote Control. Put the batteries back in. Bob's your uncle. all fixed.
SOURCE: Frozen digital screen
Set TV to standby and press Info, menu, mute then power. The set should turn on with the service menu available scroll down until you select reset press right hand arrow next to enter and then enter. TV will turn off. When switched on it goes into Plug and Play mode to reset the analogue and digital tuner. Allow a full reset then you should be ok.
SOURCE: no signal on digital TV
If you are talking about over the air digital channels I would lean toward ant problems
SOURCE: sky remote code
You will need to go to Sky's website and order a new remote if this doesn't work.
Press tv on the remote
press and hold Select and red until the remote LED blinks twice
type in 0 0 6 0
press power button on the remote, if the tv goes off press select and it should control all the tv functions.
if the tv does not go off press tv then power buttons on the remote and keep doing this until the tv goes off, then press select once the tv goes off.
Like I said earlier, if this doesn't work you will need to order a new/replacement remote via Sky's website then put the code listed above in.
