Garden Logo
Posted on Sep 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Engine cut out!
Afternoon,
my petrol engine will run for 5-10 mins and then it just cuts out,this machine is a qualcast classic 35s,belts have recently been changed,and petrol is fresh any ideas?
  • Anonymous Mar 28, 2014
    Blades not turning .
al at yahoo
Level 2:
Habit-Forming:
  • Expert 115 Answers
  • Posted on Sep 12, 2009
al at yahoo
Expert
Level 2:
Habit-Forming:
Answers
115
Questions
0
Helped
45446
Points
356
Could have water in fuel bowl or tank,coil could be heating up and stop firing or the plug
1helpful
My mower will not allow me to drag it backwards
This is belt drag, you need to take some tension off the drive cable to stop the engine dragging on the belt which in turn stops you pulling it backwards.
Apr 17, 2018 • Garden
1helpful
Qualcast classic petrol 35s
Hello david I think you need to check the air filter is clean. This should sort it.
Aug 31, 2013 • Garden
Replacing Tap on Qualcast petrol tank
It should just screw out, there is a thread on the plastic fuel tap, they can be pretty tight.
Jun 09, 2013 • Garden
4helpful
Qualcast petrol 35s mower will only operate with choke fully open, closing the choke causes the engine to cut out. Mower has been operating fine until now following a full service. What is the likely...
The chole is only ment to be used to prime the engine on cold start up, the engine is supposed to be run with the choke in the normally open position.
Aug 10, 2010 • Garden
2helpful
Qualcast Suffolk Punch 35s lawnmower running problems
There is a small idling mixture screw on the side of the carburettor.
As the engine is not well suited to the carb. it mainly runs on the idle setting!
As long as you are not leaving the choke on. This is a little tab on the top of the carb. You start with it set on C then soon set it on the middle position, and after about 3 mins turn it off.
6helpful
Need instruction manual for a Qualcast Classic Record 35s
you can go to qualcast.com and down load any manuel you need, must have serial number or part number
Oct 06, 2009 • Garden
2helpful
I have a qualcast 35s petrol lawnmower and i cant stop the blades going round when i start it it on tick over, it allways seem to be driven
Hi, first of all I would check that the cutting cylinder is correctly adjusted, i,e, just kissing the bottom blade.dont forget to re-adjust the chain. next i would remove the four engine mounting bolts and slide the engine away from the clutch drum so that you can check if the clutch shoes are binding on the spindles, if the spindles are rusty centrifugal force will throw the shoes outward to engage the drum but the springs wont be able pull the shoes back.try wd40 on the pins while trying GENTLY to revolve the shoe round the pin, hope this helps
Sep 12, 2009 • Garden
1helpful
What oil and petrol do i use for my qualcast classic 35s lawnmower
is it a two cycle or 4cycle do you mix your gas and oil or is it stright gas.
Jul 08, 2009 • Garden
Top Garden Experts
Jay Finke
Jay Finke
john h
