the message center number must have been tampered with.call your service provider customer care line for this number.then go to message>message setting>text messages>message center now click to enter the given numbers
Hello thanks for using
fixya In outbox those messages are present which are in process of sending or failed to send If u want to delete messages from you outbox Go
to the menu>>Click the message>>Go to outbox messages,you will see
your messages>> Go to options options there>>they will be second option as delete message>> Press Ok. Message will be delete I hope
this solution will helpful 4 u. Best of luck Please
keep thumbs up in do rating THANKS & Keep
using fixya
there is a service center number in your message setting. if it is edited your messages wont go . correct service center can be taken from your service provider. if that is right the reset your phone once it will start working fine.
All you have to do is go to your message setting on your phone:
1. Open Messaging
2. On New message sellect options at bottom
3. Open settings
4. Open Text message, you should see: Message centre, message centre in use ect..
5. Open message centres this should go to next screen then open again, this screen should have : Message centre name & Message centre number (from your network provider you need to find out what is the message centres name & number are e.g in Australia it should be SMSC1 and number is +61411990001) then just manually enter these in there.
wen i text any msg it doesn go it says messga send failed and resend from outbox and when i go to outbox and send it from there it says the same thing i need helpp pleasee anyone?
Hi all, I had this problem myself today- the unit receives and makes calls, receives texts but can't send them other than to the outbox.
Please try this first before taking it to the repair centre- I did a soft reset which means to restore factor settings of the unit with the sim card in (it doesn't work otherwise)
1. ** IMPORTANT**Save all your contacts and photos, etc your storage card first!! 2. Make sure the phone is on the general profile (as opposed to offline, silent or other) then type in *#7370# on the keypad. It will tell you that the phone will reset/restore settings. Click the 'ok' option when this prompt is on screen. 3. After that, you'll need to reset time, date etc. Then just copy all your contacts etc back over to the main phone and done!
