SOURCE: toshiba e-studio error code
It is abnormal temperature in the fuser*, thermistor error.
Maybe replacing fuser would help. But better contact service person.
*fuser, the part of a laser printer that melts the toner onto the medium. It consists of a hot roller and a back-up roller.
SOURCE: Wrench - Toshiba Studio E-28 error code C82.
could be a sensor blocked and the machine thinks there is paper present follow the small holes on the tray to locate sesor also keep in mind u can unplug the sorter and ur copier will work
SOURCE: CODE CD30
CD30 is an error code when there is an obstruction under the finisher trays. most of the time it is a garbage can preventing it from moving up and down properly
SOURCE: toshiba e-studio 550 call for service F10
Do the following.
Hold down 0+8 and turn the copier on.
Type in 690 then hit start.
Make sure there is the number 2 displayed.
Press enter on the touch screen.
Reboot the machine when told to.
SOURCE: Have a Toshiba E-Studio 350 in the field, and just
Wrench appear in the LCD touch screens mean "call for service". It will freeze the copier from operating until the problem is fixed.
There will be an error code appear when you press "CLEAR" and "3" button at the same time. The error code should appear next to the wrench icon you mentioned.
It is recommendable to get an experience tech to solve the problem for you.
Hi Karen Atherton, I want to help you with your question, but I need more information from you. Please Call Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7
