SOURCE: My Disney Brother SE-27OD Embroidery Sewing Machine/trouble
Can you buy embroider memory cards with out down loading on your PC?
SOURCE: Elna 8200 embroidery machine. Broken needle
Computerized machines need to be serviced by an authorized sewing machine technician, preferably Elna.
Diving into this may cause more problems and end up costing you more money for repair.
SOURCE: i have for gotten how
YOu can down load a manual from here http://www.arizonaexpressionz.com/elna_instruction_manuals/Elna7000.pdf
Just remember to click the bobbin thread into the tension device correctly and hold the two threads behind the pressure foot when you start each seam - Elna top loading bobbins give great stitch quality but you just need to keep stray threads out or they'll jam up.
Also, you must use the Elna plastic bobbin that the manual specifies for this machine - the 5000, 7000 and 9000 were Elna Tavaro Switzerland's first foray into computerised machines and first released in 1986.
Also, please check the manual when you go to buy twin needles, there are two types now as computerised machines usually need the twin needles offset from the shaft position. They have red or black plastic block between the shaft and the twin needles - I think you need the red ones but just double check the manual to make sure. And you can't do all the wide stitches with a twin needle as it will strike the foot.
Hope this helps a little.
SOURCE: elna stella air electronic
you could try www.Scribed.com or www.diplodocs.com for this one free, otherwise pretty sure it can be purchased at www.sewingpartsonline.com or relics which is www.sewing-machine-manuals.com.
Should be a blue or brown cover I think from memory.
