Heating & Cooling Logo
J
Jean Louis Robert Posted on Jul 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Contact does not shut up. The motor does not stop. I have to turn the breaker off. How do I fix it?
Thomas Woodburn
Level 3:
  • Heating & Co... Master 2,638 Answers
  • Posted on Aug 08, 2019
Thomas Woodburn
Level 3:
Answers
2638
Questions
Helped
1251816
Points
7008
Replace the contactor
Robert Wood
Level 3:
  • Master 6,140 Answers
  • Posted on Jul 29, 2019
Robert Wood
Master
Level 3:
Answers
6140
Questions
Helped
1190384
Points
20142
Appliance information needed .
Minke aire ceiling fan stopped working and won't turn back on?
There are several possible reasons why your Minke Aire ceiling fan stopped working and won't turn back on. Here are a few things you can try:
  1. Check the power source: Make sure the fan is plugged in securely and that the outlet is working by testing it with another appliance.
  2. Check the remote control batteries: If the batteries in the remote control are dead, the fan may not respond. Try replacing the batteries and see if that solves the problem.
  3. Check the circuit breaker: If the circuit breaker tripped, it may have cut power to the fan. Check the breaker panel and reset the breaker if necessary.
  4. Check the fan blades: If the fan blades are obstructed or jammed, the fan may not turn on. Check to make sure the blades are clean and unobstructed.
  5. Check the motor: If none of the above solutions work, there may be an issue with the fan motor. In this case, it may be necessary to contact a professional for repair or replacement.
If none of these solutions work, you may need to contact the manufacturer for further assistance or consult with a licensed electrician.
1helpful
Intertherm MGHA-070ABFC-05 will not run/cool
Multiple problems. Eliminate thermostat first. Remove face from wall and turn on breaker. If fan still runs you have a bad board or bad relay. If fan outside is running compressor should be too. These operate on same contactor. Verify you are getting 24 volts to coil side of contactor. If odf stops working and contactor remains pulled in you have a bad motor. If odf motor stops working the compressor will shut off due to overheating.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
1helpful
What is problem with my rascal 305 four wheel scooter
your problem is related to the overload breaker on the chair you need to figure out why the breaker is tripping either due to batteries going bad or the brushes in the motor need adjusting or replaced , also you need to check the automatic brake is releasing completly a dragging brake will cause the auto reset breaker to trip
Antenna motor will not shut off
Try and clean the entire motor and antenna setup.
1helpful
What's your problem?tread mill stop working belt stopped turning
Dear Sir:
Hello I hope you are o.k
After Reading your problem, I will help you please follow the next step:
Your problema is Electrical:
If you can walk on your treadmill but it shuts down during a workout, it is normally caused by a friction problem with the belt and deck.
Here are the most common symptoms and solutions:
If you have questions, email us at [email protected]
Symptom: The treadmill operates for a given period of time and the circuit breaker on the treadmill (if
equipped) trips causing you to have to reset the breaker, or let it cool off then reset the breaker. The
amount of time required to shut down will progressively get shorter.
Solution: The walking belt is worn. The incline test is the best test for it if you don't have a way to take a
DC amp draw. Put the treadmill at full incline and walk normally. If it takes it longer to shut off or does not
shut off at all, you need to replace the walking belt. Be sure to inspect the deck for wear too. If you want to
go for a cheap fix (that we don't recommend) try lubricating the walking belt. The best fix is to replace the
walking belt and then regularly maintain it and keep the treadmill clean.
Symptom: The treadmill will show power but after a given period of time, the treadmill will simply shut
down. Once you let it cool off, you can restart it back up but it shuts down faster and the time required
before it shuts down gets progressively shorter.
Solution: Your treadmill is most likely equipped with a heat sensor which shuts down the motor and/or
electronics to prevent them from burning up. If this is the case, replace the walking belt. Be sure to inspect
the deck for wear too. If you want to go for a cheap fix (that we don't recommend) try lubricating the walking
belt. The best fix is to replace the walking belt and then regularly maintain it and keep the treadmill clean.
Symptom: The treadmill shuts down in an intermittent pattern...there is no rhyme or reason to when it will
shut down. I get an error code or nothing shows up on the panel. I have to either unplug the treadmill or
reset it to restart the treadmill.
Solution: If you get an error code, contact me with the code and make and model and we will try to help
you figure out what is going on. Typically we either find a loose wire, an intermittent short, a bad power
board, or a bad control panel . Unplug your treadmill and then check all
your wiring to make sure nothing is pinched, crimped or loose. Remove and replace each connector in
case corrosion is causing the problem. If the problem persists, you most likely have a bad control panel or a console.
Thank you in advance, sincerely. Blessing.
If you need additional Help, please contact us.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Dryer stopped running with 30 minutes left and will not restart. Maytag Performa PYE2300AYW
Reset the circuit breaker for the dryer. Allow the motor to cool, It has over temperature protection that will shut down the motor.
The belt that turns the drum may have broken. I am not sure about this model, but most dryers have a limit switch on the base of the dryer next to the motor that shuts down the dryer when the belt brakes.
Pump does not turn on except for a humming sound and shuts off jumping the electric breaker
This could be anything from a stuck impeller to bad windings in motor. If you open the pump at the lock ring and remove the difusser from the impeller you can see if you can spin the impeller, If it won't move is it something holding the impeller up remove it. If notit is probally a bad bearing and you should replace the motor. If the Impeller turns try turning it on and caerfully try to spin before it kicks the breaker. If it is sort of stuck and does not want to turn the motor is bad and needs to be replaced. If it spins and won't start same thing, If it spins and starts it is probally a start capicator. Shut the power off at the breaker remove the back of the motor the capacitor will be a small black or silver cylinder with 2 or 3 wires clipped to it. Remove this and take it to a motor shop and get an exact duplicate. and that should fix it. When putting back together be sure to lube all "O"rings and refill with water. Hope this helps.
1helpful
My pentair controller will not shut the filter pump off
Chances are that you have a bad relay, but the problem could be the main logic board. If there is a spare relay in the box switch all the wires from the pump relay onto the spare. Remember to shut off the breaker, and also you will need to change the wires on the top of the relay too, or you will have to do some reprogramming.
Apr 05, 2009 • Pool & Spa
1helpful
My blower motor will not stop running,and my ignitor doesn't light.
I am assuming you are talking about a Natural Gas or LP furnace. The blower motor is powered by a separate 120 volt circuit, so flipping the 240 volt breaker for the furnace will not shut it off. There should be a regular light switch at the furnace that will turn off the blower for servicing the unit. When you take the cover off the unit, there should be instructions on how to re-set the igniter. If it won't re-set, try shutting off the gas for a few minutes, then turn it back on and then reset. If none of this works, and you can't find the owners manual, call a service technician.
NO Agitator, draining or spin
Since the breaker did not trip i am going to assume that the washer stopped because the motor overload switch tripped or contacts burnt. Was there any smell of any burning (electrical burning)?. It could have stopped because a contact on the timer got burnt too. Have a look also at the water level swirch
Regards
Top Heating & Cooling Experts
Paul Carew
john h
