Hi Johnie Roderick, I want to help you with your question, but I need more information from you. Please Call Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7Hi Johnie Roderick, I want to help you with your question, but I need more information from you. Please Call Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7
You can't post conmments that contain an email address.
Kindle entirely depends upon WiFi to access the internet. Following are the few simple tricks you can try one by one to fix the Kindle Won't connect to wifi error.
Refresh the Kindle Device
Switch Router
Distance of Router and kindle
Must select the 1-11 channel
Connect your kindle with the 2.4 GHz band
Press and holding down the power button for 20 seconds or more. Then turn the device back on by hitting the power button again. If this doesn't work the first time, you can try holding the button down for 30 seconds or more. Most of the time, this will be all you have to do to make the Kindle Fire work again.Oct. 11, 2014
May 26, 2020 - Perform a soft reset. A soft reset resolves many common issues without affecting any data on the device. Press and hold the Power button for 40 seconds, then release. The charge indicator light should turn on after several seconds, and then the Kindle Fire should reboot.
Fix an Amazon Fire that Won't Start. Hold Power Button. Ensure that you are holding down the "Power" button for at least 5 seconds to power it on normally. Charge Using AC Adapter. Ensure that the Amazon Fire has a charged battery. Hold "Volume Down" While Powering On. Restore Latest Software.
It could be the charger itself. Try taking the USB cable out of the charger and plug it into your computer, then plug in the Kindle. Your computer's USB port should be able to charge it. If it still doesn't charge, you might have a bigger issue with the tablet itself.
First off, I've had 5+ of that type of kindle. Each time the screen was cracked causing the screen to not turn on. If you see any lines this is definitely your problem. If so, you can either replace the screen or replace the kindle.
